Hisense 50h5c back panel problem?
  • hanswr
    • Sep 2018
    • 33
    • US
    I have searched for this model on the forums and other keywords as (bright spot, stain, faulty screen area) to no avail.
    I have a Hisense 50h5c smart TV that it is currently fully working except for a sort of a brighter area on the screen with uneven edges (like if screen was cracked). I have attached some pictures so you can hopefully better understand what I'm trying to say.
    The issue is more visible when the background picture is white. As you can see in the images when a colorful background is displayed is very hard to notice the faulty area.
    Is this something that could be fixed? I have another TV of same model for parts with a cracked screen.
    Thank you very much in advanced.
  • yokoono
    • Apr 2010
    • 485
    Re: Hisense 50h5c back panel problem?
    Dispersion film problems. The panel must be taken down and seen.
    • hanswr
      • Sep 2018
      • 33
      • US
      Thank you for you reply.
      Is this Dispersion film something that can be replaced or fixed somehow?
      • yokoono
        • Apr 2010
        • 485
        We must first see what the problem is. If it is serious, it can be replaced. If it is not serious it can be fixed.
        Turn the panel down and turn on the TV
        • hanswr
          • Sep 2018
          • 33
          • US
          I have unmounted the back panel of the second exact model tv with a cracked screen I have for practice and I can't seen to find the film or how to get to it. I have attached some pictures.
          • diif
            • Feb 2014
            • 6978
            • England
            Remove the black frame by freeing up these clips all the way round. The layers of film are held at the edges.
            • hanswr
              • Sep 2018
              • 33
              • US
              Thank you! I see that semi transparent film. I will unmount the back panel of the faulty TV and check the condition of this film.
              • yokoono
                • Apr 2010
                • 485
                Without the panel, turn on the TV. The backlight will turn on and see the condition of the foils.
                • hanswr
                  • Sep 2018
                  • 33
                  • US
                  I have a last update....
                  The problem was in fact caused by the dispersion film but I managed to crack the good working screen in the process of disassembly.
                  When trying to remove the outer plastic frame the actual screen came apart and I was unable to hold it fast enough and it fell flat on the table. It is cracked.
                  Thank you very much for the help and tips on how to fix this problem.
                  • yokoono
                    • Apr 2010
                    • 485
                    I'm sorry to hear you broke the panel. It is irreparable.
                    • hanswr
                      • Sep 2018
                      • 33
                      • US
                      I have a question regarding this TV power board.
                      What pins do I need to keep shorted to make it work as if the TV was on so I can get all the voltages?
                      I have attached 2 pictures to show the connector to main board.
                      Thank you in advanced.
                      • yokoono
                        • Apr 2010
                        • 485
                        Stb.
                        • hanswr
                          • Sep 2018
                          • 33
                          • US
                          Stb.
                          STB and any ground?
                          If so, can I just shot those to pins with a cable, or do I need to use a resistor?
                          • yokoono
                            • Apr 2010
                            • 485
                            When the TV is powered, in stb, the voltage of 12v appears ?.
                            • hanswr
                              • Sep 2018
                              • 33
                              • US
                              When the TV is on STB mode I get these voltages.
                              21v
                              21v
                              0v
                              0v
                              12v
                              12v
                              0v
                              0v
                              0v
                              0v
                              • Grunder
                                Hisense HE43A6100UTWS Panel problems
                                by Grunder
                                Panel shows two good half pictures when alternatively plugged in but poor/ distorted picture when both sides of panel are plugged in. Is this a panel or drive fault?...
                                02-23-2024, 05:16 AM
                              • ojmc
                                Hisense 65H6570G - Color inverted after replacing LED backlight
                                by ojmc
                                Background:
                                • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                • The TV worked again perfectly for ~2 weeks.
                                • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                10-17-2024, 02:29 PM
                              • Takeatry
                                Yet another Samsung QLED Boot Loop
                                by Takeatry
                                Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                10-04-2024, 02:57 PM
                              • Storyteller12
                                QN55Q60R Service Menu Panel Help
                                by Storyteller12
                                I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                01-13-2024, 01:57 PM
                                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                by sam_sam_sam
                                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                I am comparing them to a brand new one that I installed
                                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                I going to let it run for several days before I remount back on the wall next to the...
                                09-05-2024, 06:48 PM
