Panasonic LCD TV: TX-L42ETW5 won't display anything
  • lmhtb
    • Apr 2020
    • 15
    Symptoms:
    Power On = green power LED flashing until it stays green. Any remote input turns the LED flashing then turns off. Trying to reset the TV, got me a 13 red code. (TV bought in 2013, wasn't used for a few months, tried to turn it on after that period, won't produce sound or video.)
    What did I try?:
    Google lead me here to threads stating that my "A board" has to be replaced. (I assume that's where all the video inputs are.) Have looked on platforms like Ebay for replacements board, didn't find anything.
    So I wonder if I could repair it myself with your help?
    Here are some pictures of the boards:
    https://imgur.com/a/fB42rBl
    • 12206
    • U.S.
    Re: Panasonic LCD TV: TX-L42ETW5 won't display anything
    If you have a multimeter, try test number 3 below, try to do it just as instructed.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4343
      • Italy - Milan
      Try do detach the tcon board that is the one on the bottom hided by a pair of shields, and then turn on tv with antenna in and scroling channels to find one with sound.
      • lmhtb
        • Apr 2020
        • 15
        @Davi.p
        I've tried that and there was nothing. But I don't think that you can find any tv channel that way here in Germany, tho. They have changed the public tv channels to DVB-T2 few years ago.
        @nomoresonys
        I will do so as soon as I have a multimeter here.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4343
          • Italy - Milan
          Don't mismatch words, i've said to plug the antenna not to switch to analogue...
          • lmhtb
            • Apr 2020
            • 15
            So finally I got a multimeter.
            Here are my readings starting from Pin 1 to P2 to 15:
            Power On
            Power Off
            16.13V
            7mV and decreasing
            16.13V
            4.9mV and decreasing
            16.13V
            4.4mV and decreasing
            -0.37mV
            -3.7mV
            5.27V
            5.27V
            -0.37mV
            -3.7mV
            2.49V
            2.49V
            3.3V
            3.3V
            3.3V
            3.3V
            67mV
            67mV
            0.08mV
            0.8mV
            ~40-70mV
            ~40-70mV
            5.2mV
            5.2mV
            ~40-70mV
            ~40-70mV
            0.00mV
            -3.7mV
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I found some information on your power supply (page 35) which may be of some use.
              Check for 24V on P4 pins 7,8 and 9
              • lmhtb
                • Apr 2020
                • 15
                OK I've checked P4 (1-12):
                Power On
                Power Off
                5.1mV
                0mV
                0.8mV
                0mV
                67mV
                3.28V
                -4,3mV
                0mV
                -4.4mV
                0mV
                -4.3mV
                0mV
                24.7V
                15mV and decreasing
                24.7V
                12mV and decreasing
                24.7V
                10mV and decreasing
                3.3V
                3.3V
                3.3V
                3.3V
                -4.6mV
                0mV
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  You have no BL_On signal (P4 pin 2 = backlight on signal) so you need to trace it.
                  Edit
                  It looks like it may well come from IC8000 which is an MN2W50250B, a large BGA device.
                  • lmhtb
                    • Apr 2020
                    • 15
                    so if it is the ic8000, can I try to reflow it?
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      I would wait and see what others say but in the meantime you could do a search on BGA reflowing on the forum.
                      The manual I posted is not for your set but used the same power supply. Can you find the service manual for your set to confirm how BL_ON is controlled. It may be done differently on your set.
                      But what you have tested does show that the BL_ON is not being switched on.
                      • lmhtb
                        • Apr 2020
                        • 15
                        I have found one on this site: http://televid-sib.ru/index.php?topi...7497#msg127497
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          That's the power supply board only and shows BL_ON link between P2 and P4 so not of any help.
                          Can you find the mainboard schematic TNPH0993 (TXN/A10WNUE). Can't see the number clearly.
                          • lmhtb
                            • Apr 2020
                            • 15
                            I've found something here: https://****************/forum/86-85408-1
                            I am trying to register there and I am waiting for an email confirmation code, right now.
                            I've also tried heating up the ic8000 with a hairdryer for 10 minutes now, but nothing changed. I assume there was not enough heat. On this thread (same symptoms my TV has) one guy has been baking his whole A board which I could try too: https://www.badcaps.net/forum/showthread.php?t=22926
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4343
                              • Italy - Milan
                              But the backlight is working? If yes try to change tcon, or if you can wait me to be back on the board i show you some tests to be made on tcon..
                              • lmhtb
                                • Apr 2020
                                • 15
                                no, the backlight is not working. Anything I can test on the tcon board first?
                                Btw, I have failed the test on that stupid website, it's hard to answer 5 of 6 questions right when using google translator... Without passing that test I can't get the file. Had 2 tries my best was 4 of 6.......... At least, I can try it again the next day...
                                  • 12206
                                  • U.S.
                                  IS there a map/legend of the P2 connector pins on the underside of the powerboard?
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    There isn't anything useful in the zip file, just a slightly blurry photo of the mainboard without the big heatsink.
                                    • lmhtb
                                      • Apr 2020
                                      • 15
                                      @nomoresonys
                                      There is a screw I can't screw off... I've tried for 10 minutes (with pliers/drilling machine using different drilling bits and rubber). I will have to bruteforce it later...
                                      @diif
                                      thank you
                                        • 12206
                                        • U.S.
                                        Oh shit, lol, be careful not to damage it.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • proxneo
                                          Recapping Sony ICF-SW55 - verifying cap values
                                          by proxneo
                                          Dear reader
                                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                          At the moment, I have selected replacements based on the following list of values:
                                          3 x 470uF 10VDC
                                          3 x 4.7uF 35VDC
                                          4 x 47uF 50VDC
                                          8 x 22uF 6.3 VDC
                                          1 x 220uF 6.3VDC
                                          5 x 100uF 6.3VDC
                                          Which...
                                          06-21-2023, 12:38 AM
                                        • quickname
                                          Cyberpower 1500AVR UPS repair
                                          by quickname
                                          I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                          Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                          I decided to verify that the batteries were...
                                          11-12-2023, 09:57 AM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
