Inignia
  • Nama
    • May 2009
    • 127
    Inignia
    this damn thing is ticking me off. will not display video unless powering down. soon as you hit the on off switch to power down works perfectly until it turns off.... any idea's?
    ^Learning to walk on rice paper without leaving a trace,
  • Nama
    • May 2009
    • 127
    Re: Inignia
    never mind.. no idea how but it works now.
    good to be back!
    respect and blessings badcap crew
    • PlainBill
      • Feb 2009
      • 7034
      Re: Inignia
      Glad we could help!
      PlainBill
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Inignia
        Maybe you gave it a hard reset (disconnected it for an extended period) and that fixed it if it recurs then probably a bad joint somewhere.
        Insignia that's a rebranded Best Buy brand right just curious?
        • PlainBill
          • Feb 2009
          • 7034
          Re: Inignia
          I've always referred to it as a 'House Brand'. Some factory in China (where else) buys a bunch of (crap) parts and slaps together TVs by the container load. They'll put whatever brand name the buyer wants on them. The same TVs will show up under the Memorex and (I believe) Denon brand, and probably half a dozen more names at all the finer retailers like Walmart, Kmart, Target, Surplus City, Big Lots, etc.
          Warranties and parts availability range from poor to none.
          PlainBill
          • capon5153
            Macbook A1706 works perfectly but no data on USB C
            by capon5153
            hello,
            so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
            i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
            06-22-2025, 09:42 AM
          • vf fa
            EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
            by vf fa
            Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
            I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
            So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
            01-31-2024, 01:40 PM
          • bociub
            laptop freezes, usb 2.0 not working, usb 3.0 working
            by bociub
            Hi there,
            It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
            Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
            08-25-2024, 03:44 PM
          • CapLeaker
            Dell ATX PSU won’t start, but forcing it works fine?
            by CapLeaker
            Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
            Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
            10-28-2024, 06:59 PM
          • tommy97
            PS5 EDM-020 Display problem
            by tommy97
            I have a PS5 with a display issue. After clearing the cache, it works perfectly fine, but when powering the console back on, it starts with no display. To restore the display, I need to reset the cache again, after which it works normally.
            The HDMI port has been replaced, filters are fine, and the resolution adjusts automatically, so I assume the retimer is functioning correctly. HDCP is also disabled....
            08-21-2025, 12:01 PM
