this damn thing is ticking me off. will not display video unless powering down. soon as you hit the on off switch to power down works perfectly until it turns off.... any idea's?
Inignia
Re: Inignia
Glad we could help!
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Re: Inignia
Maybe you gave it a hard reset (disconnected it for an extended period) and that fixed it if it recurs then probably a bad joint somewhere.
Insignia that's a rebranded Best Buy brand right just curious?Elements of the past and the future combining to make something not quite as good as either.Comment
Re: Inignia
Originally posted by KrankshaftMaybe you gave it a hard reset (disconnected it for an extended period) and that fixed it if it recurs then probably a bad joint somewhere.
Warranties and parts availability range from poor to none.
by capon5153hello,
so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN -
by vf faHi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
by bociubHi there,
It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what... -
by CapLeakerGot a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing.O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
by tommy97Hi,
I have a PS5 with a display issue. After clearing the cache, it works perfectly fine, but when powering the console back on, it starts with no display. To restore the display, I need to reset the cache again, after which it works normally.
The HDMI port has been replaced, filters are fine, and the resolution adjusts automatically, so I assume the retimer is functioning correctly. HDCP is also disabled.... - Loading...
