LG49UJ6500 TV DEAD Need Power Supply Parts
  • bfortune206
    Burkes
    • Sep 2015
    • 23
    I can't find anything on power supply LGP49D-17U2. D805 and D806 looks like they have been hot and don't test like a diode. Can't read number on either one. Hope someone can help with the part numbers. They are near IC801. Thanks
    Re: LG49UJ6500 TV DEAD Need Power Supply Parts
    Show us good clear straight shot of the whole power supply board top and bottom sides, and the pictures of the suspected diodes.
    • R_J
      • 9625
      Do you have any voltages on P201 plug?
        • 12330
        • U.S.
        I believe they are there on the back side on either side of IC801: https://www.shopjimmy.com/lg-eay6449...ver-board.htm#
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          by sam_sam_sam
          07-01-2024, 06:34 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
