Help identifying 5-pin chip on Soniq main board
  • maneatingmonkey
    • Feb 2020
    • 36
    Chip U5 on main board LED64801-S1M1A of Soniq E48W13A is clearly blown, but I have no idea what it is. Can't find a schematic anywhere.
    I can vaguely make out some remains of letters that look like "D3R8", but I'm not confident that's what it says.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Help identifying 5-pin chip on Soniq main board
    I think you have to do some tracing to see what U5 supplies. Clean that board up with IPA so we can see better where the pins go. It looks like a buck (step down) converter to me, it is fed from U2 3.3v LDO. It may be something like 1.8v dc to dc converter. 5 pins should be Vin, gnd, Vout, enable and a FB pin.
    Something similar like this: https://cdn.badcaps-static.com/pdfs/...7c27117b1c.pdf
    • R_J
      • 9628
      It is hard to guess but it "might" be a LRC brand LR8555
      D3 is a ldo regulator, and the R8 could be date code information.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Just a guess but it looks like a dc/dc converter. Most smd regulators appear to be 3 pins plus tab. Can't quite read it but looks like A13A or pehaps 413A?
        • R_J
          • 9628
          Could be a AEROSEMI M3406 800ma, 2V-6V Input, 1.5Mhz Synchronous Step-Down Converter
          • maneatingmonkey
            • Feb 2020
            • 36
            I removed the chip and traced the pads on the board with the help of my multimeter. The same colour square indicates a path on the PCB in the photo. Given that pins 1 and 4 of U5 are shorted, that doesn't really fit with the LM3671, but does make sense for something like the M3406, where pins 1 and 4 are Vin and En. FYI the voltage at these points (with the chip removed) is 5.13V.
            • Raik
              • Aug 2017
              Maybe a little bit too late but may it helps someone else.
              I have take a picture from my LED64801-S1M1A board.
              Looks like "LD3KH".
              • Raik
                • Aug 2017
                Image...
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                  by JDC
                  ONN 100012588
                  Issue: No Power, Then Rebooting After Main Board Change
                  Short answer: replace main board and power board
                  Technical answer: replace main board and Q306 & Q307 on power board.
                  Long answer:
                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
