KDL-46HX800 blinking 4 times wont turn on
  • Msb1xr
    Have to turn on 77” LG C1 multiple times to get to come on
    by Msb1xr
    Have to turn C1 on and off multiple times for it to fully come on
    Have to run LG C1 on multiple times for it to fully work
    If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
    Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
    10-13-2023, 04:09 PM
  • ahmarzo
    Hp 15-cs laptop 5 times dc jack blinking white
    by ahmarzo
    I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
    First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
    Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
    But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
    12-28-2024, 04:46 AM
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
  • mar1in
    LG UH652T doesn't turn on and stands is blinking once a second
    by mar1in
    I've got this LG TV here that wouldn't turn on and be stuck in a standby loop (blinking red once every other second).
    Did test the following:
    * LED's seem fine as they all light up using LED Tester
    * Power Supply supplied around 111V for each LED Strips (2x edge lid strips)
    * PWR_ON would be at around 3V but dropping every other second (just like the standby light)
    * DRV_ON is doing the same
    * power supply has a green LED onboard, but that doesn't seem to do anything (stays off the whole time).
    * there is a tiny clicking...
    11-10-2024, 06:23 PM
  • SLB007
    Panasonic TX-32C300B stanbye light blinking 13 times
    by SLB007
    I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
    11-02-2025, 04:08 PM
