Philips 42” monitor need help on IC
  • finntricky
    • Jan 2014
    • 449
    Got this monitor, and the power supply is faulty, I need help to identify the IC At position U9 301 as it has blown the top and can't see what it is, also looks like resister at R9 301 is burnt next to it, I have power on the hot side of the board and nothing on the cold side,
    Just need to find out what this IC is please.
    Pics of the board added
  • finntricky
    • Jan 2014
    • 449
    Re: Philips 42” monitor need help on IC
    Full board
    • R_J
      • 9625
      I believe it is a STR-A6069H, The resistor is a 1Ω 5% 1/2watt
      • finntricky
        • Jan 2014
        • 449
        thank you very much, your a star
        • keepread
          Dell monitor PSU vs Dell laptop PSU
          by keepread
          Hi there!
          Someone gave me their old monitor, it's Dell S2715ht.
          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
          10-30-2025, 04:45 PM
        • Cornito
          Philips 50PUH6400 bad color and gosting / slow motion on one side
          by Cornito
          Hello Team,
          New issue on LCD panel where I need to find out the cause and the potential solution.
          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
          I've checked voltages, no issue found comparing right and left side of the panel driver.
          VHG VGL CKV... are the sames on...
          03-08-2024, 06:41 AM
        • Schwoin
          Philips 243v5lhsb00 Monitor Picture too bright
          by Schwoin
          Hey everyone,
          the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
          While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
          you can see them on the top half of the photo.
          At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
          03-21-2023, 12:40 PM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
          by momaka
          03-15-2023, 10:17 PM
