Panasonic TX-P50UT50E help
  • ex250
    • Jun 2019
    • 97
    • Spain
    Hello, I have this TV model and recently failed, not powering on and no blink codes. Following the troubleshooting manual, all pointed to the A main board. I found one in ebay Uk, purchased and installed.
    Received this week and all working now, that would be a great success, but I can't change the TV language, the mainboard is identical to the mine but the firmware inside is from a UK model, the TX-P50UT50B, and all other european languages were removed.
    I tried to flash the European firmware, but the board has already the latest one and it's the same number than the European, 1.267, refusing to update because the same version is yet loaded.
    It's possible to downgrade the firm or edit the file on any way to make think it's a newer one?
    Any ideas? Thanks!!
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Panasonic TX-P50UT50E help
    I think you can go into the restore all section and factory reset it. Then do the setup you want. There you can set the language.
    • ex250
      • Jun 2019
      • 97
      • Spain
      Hi, no, the reset was the first thing tried, the country selection is restricted to United Kingdom and Ireland.
      • ex250
        • Jun 2019
        • 97
        • Spain
        Researching more about, I'm /was stupid, the firmware is the same for all boards, according to this:
        https://av.jpn.support.panasonic.com...down_eu12.html
        So, regardless of the times I would reinstall (if I had been able to do that)there is something that locks the device to the region (B) in this case, and prevents all the others languages to be installed or activated.
        Perhaps some line can be edited from the service mode to change the region, but I dont know.
        • budwich
          • Jul 2015
          • 3097
          you might want to explain what / how you tried to do a factory reset of your set.
          • ex250
            • Jun 2019
            • 97
            • Spain
            Hi, tried from the menu advanced settings "shipping condition reset" and also pressing the F button on the device side + power button. Both options started with the same country selection. Is there any other way??
            • ex250
              • Jun 2019
              • 97
              • Spain
              Update, gained access to a Hex editor on the Service mode, any info about this?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Is it possible to swap the Eeprom over from the original board if all else fails?
                • ex250
                  • Jun 2019
                  • 97
                  • Spain
                  perhaps that could be possible, but not for me, I lack of the needed skills.
                  I don't know what's set on the board to make the distinction from a B to an E version, visually they are identical, also the model Id is near identical: 09 02317100 vs 09 02307100.
                  Maybe some one with a deep knownledge of the Panasonic soft could help, because I didn't find any info about the service mode possibilities. There is some thing on any place that tells to the firmware what part of the software use to change regions.
                  • budwich
                    • Jul 2015
                    • 3097
                    how / where did you find the model id.... you need to see if you can locate it in the service menu. In most sets, there are usually other "pages" that you have not shown
                    • ex250
                      • Jun 2019
                      • 97
                      • Spain
                      The model Id is on the first image, in the fourth column, on the editor only there are that menus, Flash (Lsi-data), Flash (Fake Eeprom), eeprom Peaks, and Flash (Block eep) last one Flash Cam was empty, there are many pages of hex code on each one, but no idea about the address to seek.
                      • budwich
                        • Jul 2015
                        • 3097
                        ok... then go into that "service menu" page and try changing that value.
                        • ex250
                          • Jun 2019
                          • 97
                          • Spain
                          I can't, that section is not editable like on the hex editor page, I would do it if I knew where to do it on the files available.
                          There was a page, actually down, that seemed to have info about the hex editor on Panasonic, www.nkb.me.uk but not seems available since time, and I was not able to find the info posted there on other sites.
                          • budwich
                            • Jul 2015
                            • 3097
                            you have gone into each of the "sub pages" shown on the left side of that page?
                            • ex250
                              • Jun 2019
                              • 97
                              • Spain
                              yes, but there are only pages and pages of hex codes, no descriptions of what they are about.
                              • l3emarsh
                                Firmware needed for A Panasonic TX-55FX555B 4K HDR TV
                                by l3emarsh
                                I have a Panasonc/vestel 55" 4K HDR TV and I need A copy of the Firmware.
                                I replaced the main board and someone gave me a 43" FINLUX firmware as it is a Panasonic Vestel version, it got the TV working again but the PIP will not work, I can only assume that it's because the Firmware thinks it is 43" tv?
                                I was greatfull for the TV to be workng again and it's been okay, but now I want to get it set up correctly.
                                If anyone has a copy of the firmware I need PLEASE help me out and send me A copy.
                                Greatfull for any help.
                                01-11-2022, 07:44 PM
                              • zklgfs
                                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                by zklgfs
                                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                08-11-2025, 02:14 PM
                              • TheUser
                                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                by TheUser
                                Hello to everyone ,
                                This is my first post here, and i would like to share with you a small story in case you can help me.
                                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                02-10-2024, 02:07 PM
                              • gurj1979
                                Ubiquiti firmware help. US-8-150W POE
                                by gurj1979
                                Hi guys.
                                I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                Got New chip and writes good.
                                THE PROBLEM...
                                It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                Does anyone have a Good Firmware I can have?...
                                07-22-2024, 05:13 PM
                              • Chrissygizmo
                                panasonic tx-55fx555b firmware issue
                                by Chrissygizmo
                                Hi all, am posting this for a friend so I don't have any photos of boards or anything, I know I should have all the information at hand with photos etc but I just thought I would try to find him the firmware he needs, I saw a thread on here where a user named "Diah" sent links to "l3emarsh" for the same firmware...
                                Basically, the standby light is constantly flashing & after reading posts on different sites I've come to the conclusion that it most likely is the firmware...
                                Any help would be appreciated
                                Thanks in advance
                                07-28-2022, 05:16 PM
