panasonic tx-55fx555b firmware issue
  • Chrissygizmo
    • Mar 2021
    • 114
    Hi all, am posting this for a friend so I don't have any photos of boards or anything, I know I should have all the information at hand with photos etc but I just thought I would try to find him the firmware he needs, I saw a thread on here where a user named "Diah" sent links to "l3emarsh" for the same firmware...
    Basically, the standby light is constantly flashing & after reading posts on different sites I've come to the conclusion that it most likely is the firmware...
    Any help would be appreciated
    Thanks in advance
  • nomoresonys
    • 12235
    • U.S.
    Re: panasonic tx-55fx555b firmware issue
    https://www.badcaps.net/forum/search...rchid=29714822
    • titomno2
      Surface Pro 7 type 1866 PD controller firmware issue
      by titomno2
      Hi guys,
      Hope you are fine.
      I'm struggling to fix a small issue with one of the tablet Surface Pro 7 type 1866 i'm fixing (windows 11).
      The boot time is so long (up to 5-10 minutes).
      After several attempt I finally find one thing is not right (PD controller firmware is 0.0.0 it can't update to 3.6.1) under device manager I have a yellow mark, code 14 and error as decribed on picture attached.
      I don't find any information regarding the error code 0x1803 (and sometimes it change to 0x1804.
      In the past I have found that if the update is a success, the boot...
      04-27-2025, 01:02 AM
    • wattage
      by wattage
      Hello Badcaps Community,
      07-13-2025, 04:41 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • tsitsos
      43 inch tv firmware issue.The board is cv338h-t42
      by tsitsos
      Hello all. I would like some help on installing a firmware on tv..
      4 days ago i changed a channel and the image became complete blue and the tv unresponsive. No matter what i did ( like unplugging the power , press the power button for minutes etc etc nothing helped) Then i had an idea to flash it via usb. The brand is very uncommon (smarttech) so i had hard time finding the right firmware. i ended downloading 2 just in case. I flashed the first one with usb and pressing the power button like 5 times. The installation was successful and tv worked ok with some little problems that right...
      03-11-2022, 07:32 PM
    • Ama Chur
      Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
      by Ama Chur
      After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
      02-21-2025, 08:12 PM
