Lg tv - 47lb6530-td
  • damboo
    • Feb 2020
    • 5
    • Oman
    Lg tv - 47lb6530-td
    HI!
    I would like to ask for help. I do have 47" LG TV. suddenly while watching the screen goes off and when I turn it on again the RED LIGHT blinks three times and will become steady without the screen on. I suspect the PSU got damage. I pull out the PSU and checked the supply pin going to the mainboard and getting all the specified voltages like 3.5v, 12V, power on, PPDIM2 and PDIM1 except I'm not able to get the 24v. Does it mean the PSU is fine or maybe the mainboard is the one damage?
    PLS HELP!
    THANKS!!!!!
  • damboo
    • Feb 2020
    • 5
    • Oman
    Re: Lg tv - 47lb6530-td
    Originally posted by damboo
    HI!
    PLS HELP!
    THANKS!!!!!
    I attached the PSU diagram
      Can we see good clear straight shot of the whole top and bottom side of the power supply boars?
      • damboo
        • Feb 2020
        • 5
        • Oman
        I really don't know what just happen. but I'm getting now the voltages 3.5v,12v, and 24v but no backlight. but no voltage reading at DRV-ON, P-DIM1 and P-DIM2. as I understand to the BASIC LCD TROUBLE SHOOTING you had shared to me (thank you for that). 12v and 24v would not turn on without pressing the power button switch. but on my case, once the tv plug in to 220v the red power indicator immediately blinks 2 or 3 times and become steady without pressing the power on button. and at the same the other voltages are on except for those DRV-ON, P-DIM 1and 2. I begin to doubt the mainboard is defective.
        I uploaded the PSU images.
          • 12192
          • U.S.
          Why would you doubt mainboard issue, drv-on signal COMES from mainboard so I am doubting the mainboard.
          • damboo
            • Feb 2020
            • 5
            • Oman
            Thank you guys for helping me out. I would replace the mainboard.
            • Mirenia
              Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
              by Mirenia
              I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
              I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
              In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
              The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
              03-30-2025, 06:47 AM
            • Devonavar
              Vizio M43-C1 - How closely do I need to match the mainboard number?
              by Devonavar
              I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
              I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
              Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
              So, I've ruled out the PSU for now.
              The reboot loop...
              08-14-2022, 08:46 PM
            • Malva
              Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
              by Malva
              I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
              Mainboard model: EAX65684604
              PCB marking: EBT62954607
              SPI chip: Winbond W25X20CLNIG Problem description:
              Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
              After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
              • I bought another
              06-25-2025, 02:07 PM
            • l0lhaxz1
              QN65QN90A - Mainboard MLCC failed - now bootloop
              by l0lhaxz1
              Hi
              I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
              Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
              Came to learn after a bit more research...
              02-06-2023, 08:59 AM
            • Jembang
              coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
              by Jembang
              good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
              11-01-2024, 09:55 AM
