Prima LC-27K6 27" LCD TV Help
  • lucky13
    • Aug 2007
    • 412
    I am helping someone with a problem with their Prima TV.
    The original problem was that the TV won't start. The red LED went off and back to red LED after a few seconds. When it works, the LED will turn blue and the picture will start.
    He ordered a P/S from somwehere and replaced it. It worked for about 3 weeks and the same thing happened again.
    He is a bit reluctant to order another P/S.
    This is where I come in.
    I looked at the original P/S and there are no domed caps. I left my ESR-Micro at work..
    I found the s/m for this TV here:
    S/M
    Page 37 is the schematic for the p/s. It pretty well matches with what I see inside.
    Now, this p/s puts out 24V & 5vsb. I checked with DMM and the 5v is there. No 24v.
    To check the functionality of the p/s, I removed it out of the TV.
    Can I jumper pin 2 to pin1 on the p/s output to force the p/s turn on (maybe then see if 24v rail comes up)?
    Thanks guys.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Prima LC-27K6 27" LCD TV Help
    I don't think so. It appears pin 1 is the control pin. IF I am reading the schematic correctly, it must be driven high to turn the TV on.
    PlainBill
    • lucky13
      • Aug 2007
      • 412
      On page 37, pin 1 is connected to the output of T903 and I have 5v there with just the ac power connected. X903 is not connected to anything.
      The 24v on pins 6-8 are 0.
      That's why I think I should be able to short pin 2 to pin 1 thus sending 5v to V905 and maybe something will happen (hopefully not a BOOM).
      I don't know if 24V rail is enabled by the action on pin2.
      Anyone?
      • bobco631
        • Jan 2011
        Hi, ... I've got the same problem with my Prima, red light issue, no blue. No power, no picture. Did you ever work out the power supply issue?
        • cadiman
          • Mar 2010
          • 397
          If the power supply turns on sometimes. test or replace caps on power supply.
          Was the power supply replaced with a used one? Both supplies have the same problem?
          I don`t like forcing something to turn on unless It tells sme how to do it for troubleshooting. ( pioneer 50hdt50 plasma troublshooting the power supply ).
          • Lucky2024
            by Lucky2024
            About ECS laptop ed20pa2 bios password Buongiorno,chiedo per far favoro se e possibile avere la password di questo codice ( 7L16E5UE) e la prima volta che scrivo in questo gruppo spero di non aver sbagliato​
            12-22-2023, 03:58 AM
          • Lucky2024
            by Lucky2024
            About ECS laptop ed20pa2 bios password Buongiorno,chiedo per far favore se e possibile avere la password di questo codice ( 7L16E5UE) e la prima volta che scrivo in questo gruppo spero di non aver sbagliato.grazie mille di cuore ​
          • neilc6
            Prima LC-3237D Washed Out Screen
            by neilc6
            I recognized this problem as a bad Tcon and specifically a classic AS15F chip failure. This would be my first attempt at this type of repair without a proper rework station.
            Borrowing a heat gun, I replaced it with a RM5101 off another Tcon board. Checking the screen, it appeared fixed, so I put everything back together and further testing indicated it was not fixed since the video had image retension (like burn in) and was a bit dark.
            I just bought Hakko 937D clone off ebay with super fine tips so figured I'd touch up the joints. There appeared to be a short on one...
            06-11-2017, 05:26 PM
          • uberplasma
            Prima PH42T7 - No Power
            by uberplasma
            Hi
            I am looking at at Prima PH42T7 that has no power/sound or LED, although I know it is drawing current. No relay clicks or pops in the audio when the mains are connected. I have not yet found the service manual for this one, but from the test point voltages on the PCB's I get nothing but millivolts in the dc range and around 2.5v AC instead. Anyone seen this or know if it is just the rectifier?Anyone know how to get the error codes to flash(although no LED) Any insight or links to the manuals would be greatly appreciated. Like other posts I have seen about the Prima, the boards are samsung...
            10-01-2011, 07:08 PM
          • starmaxpc
            Prima 21 inch lcd powers on then goes dark
            by starmaxpc
            got one of these from a friend who was gonna toss. it powers on fine led is blue stays blue screen lights up for 2 seconds with "PRIMA" on screen then gets kinda like a fuzzy screen you would get after a station goes off air then it goes black. led blue light stays on till i hit power button then goes red. none of the caps on board are bulged/leaking. nothing looks burnt/broken. i will post pic shortly.
            01-13-2010, 08:50 PM
