UN60J6200AFXZA Backlight issue
+ More Options
Posts
  • ShatterMasters
    • Oct 2017
    • 14
    Hello!
    I got a TV in my repair store with symptoms of bad LED's. We tore it down and tested the LED's and found bad ones so we ordered replacement strips.
    Now after replacing the strips they still are not wanting to turn on. Its like the PSU is not detecting the LED's because the return lines at the connector are the same as the output. Ive tested for bad connectors and can't seem to find any.
    Not sure what to do now!
  • neilc6
    • Nov 2015
    • 1550
    Re: UN60J6200AFXZA Backlight issue
    Bad LEDs can damage the power supply. Seen damage to diodes, FETs and the controller IC. Pictures of the power supply board?
    • ShatterMasters
      • Oct 2017
      • 14
      I noticed its pretty dark by LED output. It is outputting 403v and taking back 403 on the other side
      • neilc6
        • Nov 2015
        • 1550
        Did you check those diodes and the FET in that darkened area for shorts?
        • ShatterMasters
          • Oct 2017
          • 14
          I have not yet. In my mind I was thinking if it output power then the board was most likely working. I can do that though!
            Remove D9001C and check the RESISTANCE in both directions, it should not show resistance in BOTH directions.
            • ShatterMasters
              • Oct 2017
              • 14
              I saw your post about this on another thread with the same PSU.
              Just tested it and it looks like it is getting the same both ways. 0.1 OHM's.
                Replace it.
                • ShatterMasters
                  • Oct 2017
                  • 14
                  Sorry that was for BB90004
                  D9001c get 5.6k one way and 3.0k the other direction. So your answer will be the same to replace it. I'll see if I can find one on DigiKey
                  • ShatterMasters
                    • Oct 2017
                    • 14
                    Replace it.
                    Does this look like the correct one?
                    https://www.digikey.com/product-deta...QaAh64EALw_wcB
                      What is the P/N of the bad one?
                      • ShatterMasters
                        • Oct 2017
                        • 14
                        Couple different sets of numbers but SF28G is what I think it is.
                        Others are jf25, siyu
                          That replacement is fine.
                          • ShatterMasters
                            • Oct 2017
                            • 14
                            Thanks for the quick help! You are the man.
                            • bottemann
                              • Apr 2014
                              More feedback for the group.
                              I just fixed my UN60J6200 which had the identical issue.
                              Found 40 shorted and 1 open LEDs.
                              After installing a new LED set from shopjimmy,
                              it still didn't work, though they lit up with the LED tester.
                              PSU (BN44-0775A) had a bad C9001 diode (SF28G) which
                              showed 900 ohms both ways. Used a junk box NTE577.
                              Awesome!
                                Thanks for the feedback on your repair.
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  I got one of these and waiting for new strips but suspected power supply damage because in Samsungs, the screen is normally dim with no shutdown from shorted LEDs. For search purposes, corrected power supply part number is BN44-00775A . SF28G is 2A/600V and available from Digikey.
                                  • neilc6
                                    • Nov 2015
                                    • 1550
                                    I replaced all the strips (63 out of 84 LEDs were shorted) and D9001 tested ok. Usually if the FET and diode test good, I suspect the controller IC is damaged. Board is pretty expensive on Ebay but Buyqual sells a substitute board. I have ordered a substitute board from them previously and it was ok.
                                    • Plurxtc1
                                      • Oct 2014
                                      • 136
                                      Is the controller IC the 7014X?
                                      • neilc6
                                        • Nov 2015
                                        • 1550
                                        I've got 3 damaged power supplies from Samsungs with bad backlights. Diode and FET all tested good and no backlight with all new strips and ended up replacing the power supply.
                                        The other two are BN44-00772A from UN50H6203 and BN44-000769C from UN40H5203. I can only see the marking clearly on BN44-00772A as 7014X.
                                        Might as well order some on Aliexpress and see if it fixes these 3.
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • lmcancu
                                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                                          by lmcancu
                                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                                          Instead of putting it back together I decided to replace...
                                          04-01-2023, 01:11 PM
                                        • shellybelly
                                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                          by shellybelly
                                          Back Story
                                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                          08-27-2023, 10:40 PM
                                        • Riananyaina
                                          MacBook A1708 820-00840-A backlight issue
                                          by Riananyaina
                                          Hello Everyone ,
                                          today I'm coming to you regarding my issue which is no Backlight .
                                          I have image on my screen but no light .
                                          The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                          First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                          Please find below few informations which can help for the analysis...
                                          04-24-2023, 05:03 AM
                                        • Yanleb
                                          Vizio M70-D3 4K with dark spots backlight issue
                                          by Yanleb
                                          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                          03-22-2022, 01:06 AM
