crystal tv WB-32H8C
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    crystal tv WB-32H8C
    Board is tp.v56.pb816
    i need eprom please
    the problem is that when i press the power button, the power led will tuen blue for seconds then red again
  • Woodsworth
    PS3 CECHC03 60GB YLOD Troubleshooting
    by Woodsworth
    I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
    START
    Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
    03-19-2024, 07:58 AM
  • ktmmotocross
    Lenovo Legion 5 Pro 16ACH6H bad crystal?, but now wont program. connection lost after 5 seconds
    by ktmmotocross
    Hello.
    Have this Lenovo Legion 5 Pro 16ACH6H that came with no start, only powerbutton light. i reflash bios and ec. no change. i replace one of soc cpu crystals and laptop start to work. but when i assemble it, keyboard not work. so i reflash back bios but when i try to reflash ec i get write error and now i connect to it but always read/write error and connection lost after 5 seconds.
    IC is ITE8277E - 256 programmer is vertyanov. i try to change back that crystal but still the same
    NM-D562 rev3.0
    sn- PF31EESB
    any ...
    01-22-2024, 05:33 AM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • twonk9098
    Lenovo Legion 5 high fan spin turns off after 34 seconds
    by twonk9098
    I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
    I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
    I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
    I have tried a few new bios but exactly...
    07-14-2024, 11:19 AM
  • pc_okay
    Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
    by pc_okay
    Hello friends,
    Its been a while, i wish you an happy new year 2025 !
    I have this laptop doesn't start, power light up a second when pluging USB-C charger.
    Laptop take 0.11A.
    All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
    I get no oscilation on XTAL 32.768 KHZ
    Battery is not charging but charging led is here.
    PCH heat at 30° approximatively. (with no heatsink)
    I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
    It's a 2 pins Crystal.
    01-13-2025, 09:26 AM
