LG 42LB5600-UZ No Picture, Sound OK
  • TheRic
    • Apr 2017
    • 11
    Backgroud
    I have a LG 42LB5600-UZ, The screen is dark but sound works. When doing the flashlight test I can see the picture.
    Ground on Chassis
    Tested the voltage at the backlight connector, it hangs at 102VDC. When I first turn on the TV, the voltage at the the backlight jumps up to about 260VDC after about 1-2 seconds, then ramps down over about 5-10 seconds down to 102VDC. I get the same voltage with the LEDs connected or not connected.
    Ground on LED-
    Tested the voltage at the backlight connector, it hangs at 0.01VDC. When I first turn on the TV, the voltage at the the backlight jumps up to about 150VDC after about 1-2 seconds, then ramps down over about 5-10 seconds down to 0.01VDC. I get the same voltage with the LEDs connected or not connected.
    Questions:
    Is this normal voltage? I've read where it's supposed to be a higher.
    I'm assuming it's bad backlight. I figured I would just replace the LED's, read it's a heck of a lot cheaper. How/where do I find out what LED's I need? Is there a standard?
    Thanks for your help, If you need more info just let me know.
  • R_J
    • 9633
    Re: LG 42LB5600-UZ No Picture, Sound OK
    The power supply supplies a base 102vdc for the led circuit, the led BOOST circuit will boost that voltage to light the led's, to around 208vdc, the fact that it is around 260VDC indicates an OPEN led string in the panel.
    It won't be cheaper if you crack the panel so be carefull with it and remember the diffuser sheet sequence so they go back the same way.
    Lokks like shopjimmy carries the led strips for this model
    • neilc6
      • Nov 2015
      • 1550
      These are likely your strips though you should open up the panel to confirm the part number printed on them. https://ebay.us/xnlym6
      • TheRic
        • Apr 2017
        • 11
        Thanks for your help.
        To clarify was talking of replacing individual LED's verses the strip.
        I have Part Number/Model Number for the Backlights / backboard assembly as T420HVF07.1
        • R_J
          • 9633
          Which ever way you go, make sure to check the led operation, BEFORE reinstalling the lcd panel. The tv will turn on and light the led's without the panel connected.
          If you just replace one or two led's having them lit will help in realigning the lens
          • neilc6
            • Nov 2015
            • 1550
            I would recommend just replacing all the strips. The working LEDs have wear and are likely to fail in the future. The tape for the strips is super sticky and you are likely to pop off the lenses removing the strip. The lenses if they aren't lined up exactly will cause halos when reglued.
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • JohnML1975
              Samsung UA50TU8000W no picture and no sound
              by JohnML1975
              Hello All
              have seen posts on this model in here but my problem sounded different so thought i would create a thread
              TV will not turn on
              There is no standby light
              When I press ON button for remote the red standby light does flash but no picture and no sound
              From the back of the TV I can see the red light on the back of the mother board
              Holding torch to the screen I cannot see a picture
              I removed the back cover
              Observing the boards I cannot see any damage
              I disconnected the main board from the power supply
              the back...
              08-30-2025, 09:40 PM
