Sony KDL-32WD600
  • bootpanic
    • Nov 2019
    • 20
    • Belgium
    Sony KDL-32WD600
    I have a Sony KDL-32WD600 which is completely dead, no power led, nothing...
    The problem has something to to with the control circuit for powering the TV on. When i bridge source and drain of the FET that is switching the 19,5V from the mains adapter to the DC/DC converter the TV is powering on and working normally.
    Service manual and or schematics would be a great help.
    Thanks in advance!
    Cheers!
  • yokoono
    • Apr 2010
    • 486
    Re: Sony KDL-32WD600
    What is the power code ?.
    • bootpanic
      • Nov 2019
      • 20
      • Belgium
      What do you mean by "power code"
      Here is a picture of the label.
      • yokoono
        • Apr 2010
        • 486
        You did not specify that it is external power supply. To be easier to find, you must then specify the main code.
        Are you sure the external power supply is ok?
        • bootpanic
          • Nov 2019
          • 20
          • Belgium
          Yes i am sure the power supply is not the problem. I have powered it from a bench power supply with the same effect.
          When i bridge the source and drain from the FET (TPC8129) that's sitting in front of the incoming 19.5V the tv powers on and is working normally.
          PS: The red (visible in the picture) and black wires are soldered onto the DC power socket for powering it from my bench power supply as i don't have a spare 6.5/4.4mm DC plug.
          • yokoono
            • Apr 2010
            • 486
            The mosfet order comes from the processor. It may be a imperfect contact to the processor or a software alteration.
            • bootpanic
              • Nov 2019
              • 20
              • Belgium
              Without schematics it is hard to follow where the gate is going to (read coming from).
              I measure -50mV on the gate of the mosfet relative to the positive of the supply voltage which is way to little to turn the mosfet on.
              Probing around i did not found any supply voltage going to the processor...
              • bootpanic
                • Nov 2019
                • 20
                • Belgium
                I have connected the gate of the MOSFET (TPC8129) over a 10K resistor to ground. Now the TV powers on and seems to be working normally. I can turn the TV on and off, drawing about 10mA when off.
                I'm wondering what the exact function of the mosfet would be???
                Maybe someone can shine some light on this?
                • bootpanic
                  • Nov 2019
                  • 20
                  • Belgium
                  Here is a picture of the mainboard.
                  • R_J
                    • 9551
                    If the mosfet is used to control the 19 volts, there must also be a regulator somewhere that supplies the microprocessor with standby voltage, It could be that that regulator is not working. When you turn the tv off you are likely only turning off part of the tv's circuits. Have you checked all the small fuses on the board?
                    With the resistor in place on the gate, does the fet turn OFF when the tv is turned OFF or is there still 19 volts on the drain and source?
                    • will62
                      • Dec 2016
                      • 229
                      • usa
                      Take a look at the attached SM. Slightly different model, but power section layout looks similar. Perhaps you can use it to help you track down your 5V standby.
                      • bootpanic
                        • Nov 2019
                        • 20
                        • Belgium
                        Yes, all the small fuses seems to be OK.
                        No, the mosfet stays on all the time with the 10K resistor connected from GND to the gate (19,5V present at PIN5-PIN8 of the fet when TV is off).
                        The TV only draws 10mA from the 19,5V supply when off.
                        • bootpanic
                          • Nov 2019
                          • 20
                          • Belgium
                          Thank you very much!
                          This SM helped me a great deal in narrowing the problem
                          • bootpanic
                            • Nov 2019
                            • 20
                            • Belgium
                            I'm not sure the fet is actually controlled by the processor. There are 2 other transistor like devices in the protection circuit. When the TV is off with the 10K resistor on the gate of Q6020 present it draws only 10mA...
                            I'm suspecting the SMD marked 31. When following the "Protection Circuit– Checking Procedure" in the SM it boils down to Q6019 damage...
                            I think there is a good chance that the SMD marked 31 in the picture might be Q6019. If Q6019 is a normal transistor it certainly is broken, got some weird high values with DM on diode test.
                            There is as far i can find no mention of the type of Q6019 in the SM. Does anybody know what type it might be?
                            • will62
                              • Dec 2016
                              • 229
                              • usa
                              Here's a data sheet for a PNP that has a marking code 31.
                              • bootpanic
                                • Nov 2019
                                • 20
                                • Belgium
                                That looks like a good candidate!
                                Just ordered 10 of those.
                                Thanks!
                                  Did you check the junctions of that PNP Transistor to see what they show? Check the Voltage readings?
                                  • Carlos#2003%
                                    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                    by Carlos#2003%
                                    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                    02-15-2024, 07:52 PM
                                  • blake.s
                                    Sony XR-65X90J & Sony KD-55X80J Not Powering On
                                    by blake.s
                                    I have two separate tv's that are having the exact same symptoms. A Sony XR-65X90J and a Sony KD-55X80J. They both are not powering on at all and do not show any led light status. I am having issues with getting the backs off because both sets are the screwless type. Not sure if anybody has any ideas on if it is indeed a power supply issue or these types are known to have other issues.
                                    Also, any ideas on how to get the sets backs off?
                                    09-16-2021, 01:03 PM
                                  • dkneyle
                                    Sony KDL-46HX850 Can't upgrade/update firmware
                                    by dkneyle
                                    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                    09-25-2024, 10:44 PM
                                    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-06-2024, 05:27 AM
                                    Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                    This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                    09-06-2024, 05:30 AM
