Ch341A software/driver - Your setup
  • Acca
    • Jul 2017
    • 47
    • Italy
    Hello guys,
    I've recently got me a new laptop to use for work and it's great and all but I don't know if I'm having bad luck or what but recently I'm facing more issues than before, while attempting to fix some tvs, with my trusty (and dirty cheap) ch341a (black pcb) and IC/firmwares.
    I'll write my questions first:
    1) Which program and version are you using to program the ICs?
    2) Which driver
    3) Which OS/version are you on?
    I need to set a base of which I can be fairly sure about. I mean, if I put an IC in the programmer and it says that it can't identify/erase/program/whatever it I can be sure it's the chip's fault.
    My setup now:
    1) Program is CH341A ver 1.34 (I'm trying AsProgrammer 1.4.0 too)
    2) driver version 2.2.2009 6
    3) Windows 10 1909
    I've read somewhere that for Win10 is better to use the version 1.29 of the program, I've tried to use the newest driver from here but looks like windows doesn't want to use this 2019 version and sticks with the 2009 version.
    Thoughts, comments, suggestions?
  • yokoono
    • Apr 2010
    • 514
    Re: Ch341A software/driver - Your setup
    Soft
    http://televid-sib.ru/index.php?topic=42039
    • Acca
      • Jul 2017
      • 47
      • Italy
      Originally posted by yokoono
      Hey thanks a lot for the link, I had to google translate it but looks like an active project.
      I've programmed a 25q32 to test it and it worked, I'll have to wait for a real world test tho.
      • NeedsPractice
        Best Overall Amazing Back Up Setup? 1K-4K Budget! Software + Hardware? Help!
        by NeedsPractice
        I remember a lot of people before when my hard drive failed told me that I could do a couple of amazing things with backing up data. What stuck out is two things...
        1. Software that will backup your data live via a cloud solution or over the internet without having a corporate cloud product.
        2. Get a storage tower with hard drives and load them up.
        What I mean is there software out there that you can install on your computer. You tell it which data you want backed up. Lets say your main PC with (2) hard drives and (8) hard drives connected to it via a tower....
        06-23-2023, 05:26 PM
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • Squaryhead
        Which software for GD25LB128 with CH341a
        by Squaryhead
        I'm struggling to find a software to reconfigure a GD 25LB128 chip with a CH341 A.
        Do you know any ?
        Thanks !
        05-07-2024, 08:15 AM
      • intelg
        HP Elitedesk 800 G6 lost BIOS admin password
        by intelg
        Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
        Here is the hardware identification specs:
        HP EliteDesk 800 G6 Desktop Mini PC
        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
        BIOS ver S21 Ver. 02.05.01 01/05/2021
        Born on date: 07/26/2021
        SN MXL11841GN
        SKU 3X8V9UCHABA
        UUID 8116E79EF6FFE94DB0B98A3188270C5C
        SYSTEM BOARD ID 8710
        SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
        11-03-2023, 02:05 AM
      • md500
        [Question] Ch341a and 5v to 3.3v with logic converter
        by md500
        zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
        Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
        What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
        I can't buy the ch341a 1.6v that has...
        05-24-2024, 06:51 PM
