LG 60pv400 gets faint image on screen for 2 seconds
  • woodman45
    • Aug 2015
    • 87
    • U.S.A
    This LG 60pv400 red light comes on after plugging in.when you turn power button on red light goes away then faint snow image comes on for 2 seconds then goes out.press power button as in to turn off red light will remain.
    I did confirm on power supply test points vs=200 va=54
    I followed from ps to both y and z boards and they both are matching voltages from ps.
    I did tested all capacitors on video board all read good with no shorts except c809 and c810.
    My question is if I replace those should that resolve the problem or is there something else I need to look at?
    Thanks in advance.
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: LG 60pv400 gets faint image on screen for 2 seconds
    Have you read all the threads here on this model? Search the model number and you will get a ton of clues what to do. Pattern tests, cracked solder joints, blown IBGTs on zsus and ysus boards, and don't power the tv on with screws missing. Do a little research. It will steer you in the right direction.
    • woodman45
      • Aug 2015
      • 87
      • U.S.A
      Yes I've been going through all the threads here and the trouble I'm having is identifying which are the test points. I've never done a jumpered test pattern.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Unplug the power cord. Un-latch the ribbon circled in black. Put a paper clip in both the holes circled in red. Plug the tv back in and look for the test patterns on the screen.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Forgot to post the picture.
          • woodman45
            • Aug 2015
            • 87
            • U.S.A
            Thanks tvtimmy, I ran the jumper and unplugged cable plugged tv in no test pattern showed just the faint image for 2 seconds and disappeared.
            • woodman45
              • Aug 2015
              • 87
              • U.S.A
              I starting checking fuses and fs103 on zsus board is blown.I looked at inductor solder joints and there was cracks so i reflowed solder on them.
              I'm guessing the next step is to test igbt's and other components.I will research other threads and get back.
              I took ysus board off and noticed cracks in the inductor solder joints,I'll re-flow them later tonight or tomorrow.
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                Always remember to put ALL THE SCREWS back in the zsus and ysus boards before plugging the tv back in.
                • woodman45
                  • Aug 2015
                  • 87
                  • U.S.A
                  Yes I've read how important that is for the boards to be properly grounded.I appreciate all your help tvtimmy.
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    No problem, let's get 'er fixed. When you find the bad ibgts, I have a method of getting them out. Involves some snipping of the heatsinks.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      There are smaller fuses on the y and z boards too.
                      • woodman45
                        • Aug 2015
                        • 87
                        • U.S.A
                        Do the igbt’s have to be out of circuit to test? And do I test them in continuity mode?
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          You can test them in the board. Yes , test them in continuity mode. Any combination of beeps is bad. The diodes will beep too because the ibgts are shorted and in the same circuit. Test the parts marked with a "Q".
                          • woodman45
                            • Aug 2015
                            • 87
                            • U.S.A
                            Ok I tested all the Q ones and most of them are bad.beeping away.i pulled the y board no beeps on them.
                            If I get a repair kit should it include all the igbt's or do you have any recommendations?
                            Also the fuse that you posted a pic of is showing good.
                            • woodman45
                              • Aug 2015
                              • 87
                              • U.S.A
                              Q201.202.203.204,205,206,207 no shorts. Q208,209,210,211,212,213 shorted.
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                I've ordered parts from this guy before, always good stuff from him. Look up your board number and search for it on Ebay.
                                • woodman45
                                  • Aug 2015
                                  • 87
                                  • U.S.A
                                  I found this on eBay for $20 so I'm gonna have to desolder and pull the heat sinks completely out right?
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    I've only had the bad ibgt's on the 2 that I repaired. No bad resistors. You have to be very good at soldering to change out the IC driver chips.I took a tin snips and cut the overhang of the heatsink above the bad parts and bent them up so I could get to the screws. I think I removed some capacitors that were in the way too. I bent the cuts back down when replaced.
                                    • woodman45
                                      • Aug 2015
                                      • 87
                                      • U.S.A
                                      I found the ibgt's from the guy you got em from.I'm gonna get them.Man i appreciate all your help and tips. I'll get back when i get them and start working on it.
                                      • ajshoe
                                        ajshoe
                                        • Dec 2012
                                        • 477
                                        • usa
                                        I've used this guy before also - not competent. sent him 3 power boards to repair and he shipped them back like an 8 year old would. boards came back all broke. I'll never use or trust him again. Had to agree with fleabay so unfortunately I couldn't give him negative feedback. just my 2 cents worth
                                        • waakye
                                          ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
                                          by waakye
                                          I was giving this ASUS ROG G750JM that exhibit the following behavior:
                                          When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
                                          My issue is the laptop doesn't stay on for a long time and turn itself off.
                                          Any lead on how to resolve this will be appreciated.
                                          I cannot boot in windows and no liquid damage.
                                          Thanks in advance.
                                          09-13-2024, 08:10 PM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • ss45
                                          Nintendo switch faint image black screen
                                          by ss45
                                          Hi folks
                                          Like the title says, Initially the device didn't have image, turned it was a backlight connector problem. I shone light into the LCD there was clear image, only dark
                                          After soldering new BL connector, the backlight works perfectly. Here is the big F up. During plugging lcd connector, I bent some pins unknowingly.
                                          Put it back together, turned it on, surprised, backlight is on but there is no image now. Well, sort off. I i see carefully there is faint image resembling normal one, but only on right part on the screen albeit really hard to make it out....
                                          03-05-2022, 09:06 AM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                        • Lisanimaux
                                          Toshiba FireTV image jumps every two seconds. Can it be fixed?
                                          by Lisanimaux
                                          I don't know if someone can help me, but I'm going to give it a try anyway! I made sure to look up my issue before posting, but I couldn't find any thread for this TV model. I should also mention that I never fixed a TV before, please bear with me!
                                          My Toshiba 43LF621U19 REV. B started acting up lately. I tried looking up its "symptoms" online, but I can't seem to find anyone experiencing the same problem, which makes it hard to figure out if this can be fixed and/or which part(s) should be replaced.
                                          The TV was purchased brand new in June 2019....
                                          01-13-2021, 11:04 AM
