TV Samsung LE40A656A1FXXC variable color bars image
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    TV: Samsung LE40A656A1FXXC
    T-Con : BN81-01694A
    Motherboard: BN94-01741B
    LCD Display: Samsung LTF400HC01
    Hello all, I need your help again, then I joined 2 pictures as it is an image issue.
    The image is sometime correct, sometime partially good, when it has a partial good image it is always on the top of the screen, sometime no image at all just only color bars as a gradient moving with the image contain like a curtain.
    I check already every ribbons and powers, I hesitate to say it is either the diplay or T-Con problem, can you help me please ? if coming from the t-con, any idea which chip may cause such issue ? The t-con looks no more available.
    Thanks by advance.
  • yoritomo
    • Sep 2012
    • 155
    • Belgium
    Re: TV Samsung LE40A656A1FXXC variable color bars image
    Hello all
    Unluckily this time I don't have a salvaged T-Con to clarify this fault, as I could with many other ones. I have the oscilloscope but I don't really find any interesting signal to check on the panel side ... That is annoying i feel like having both hands in pockets on this kind of fault. On t-con board, I know already how to troubleshoot the power chip and gamma chip, but that is all, i miss knowledge about other parts and operations on it.
    Good night all
    • petehall347
      • Jan 2015
      • 4448
      • United Kingdom
      maybe poor soldering . try heat from hair dryer .
      also try twisting the frame a bit .
        • 12330
        • U.S.
        Maybe try the "cut tape" method, might not work but only cost the price of a piece of tape, sometimes have to play with position of tape, usually works when a gate driver is the issue, your fault doesn't look like the typical bad gate driver but who knows: https://www.youtube.com/watch?v=j7vl7-vZEL8
          • 12330
          • U.S.
          Could also try cleaning and re-seating ribbon cables from tcon to panel, some use a pencil eraser carefully don't want to damage them and lvds cable from tcon to mainboard and make sure they fit securely.
          • yoritomo
            • Sep 2012
            • 155
            • Belgium
            Hello all, thanks for your replies.
            petehall347
            I did already, no change, moving the frame of display ribbons did not show any change.
            Yes that is the first think i did, and i used a tuner contact cleaner too in complement, vibrations on t-con board did not gives any results neither.
            • yoritomo
              • Sep 2012
              • 155
              • Belgium
              Hello all
              This did not work, i still don't understand how to mask tracks may provide a correct image ... he does not explain on the video which tracks to masks or how many of them, anyway the concerned problem is not the same at all, thanks anyway for the hint.
                Does heating of the main board have any affect?
                  • 12330
                  • U.S.
                  Originally posted by yoritomo
                  Hello all
                  Nothing is absolute and just like a bad tcon can present in different ways so can other problems, it's troubleshooting and it's not always easy.
                  • yoritomo
                    • Sep 2012
                    • 155
                    • Belgium
                    Hello all
                    Heating T-con and motherboard did not change anything as well as twist and vibrations.
                    It is right nomoresonys, sometime our job is doubled by some magic
                    Thanks again for your help
                    Have a nice day
                    • yoritomo
                      • Sep 2012
                      • 155
                      • Belgium
                      Hello again
                      I have some new clues
                      When the image looks normal, it has an issue anyway above clear writing on the screen, difficult to see on the picture, then i will describe it, i have on this image writings on bottom left of the image, it has kind of blue red and green fine vertical line, starting from there to the top of the screen, nothing below !
                      Other thing interesting , when the images is garbled and i place my finger on the t-con board, on the place marked by the red circle, the image is freezing, when releasing my finger, the image becomes normal. there is a power supply chip TPS65160A just beside. Perhaps i am doing a reset downing a power line there. I am not sure what to think about it.
                      Have a nice day
                        09-07-2024, 05:50 AM
                      • shlomim412
                        samsung ua55es6800 - no image
                        by shlomim412
                        hi
                        having problem with samsung ua55es6800
                        tv had backlight on, sound working - responds to the remote control but no image.
                        check tcon board - had 12v in but no other voltages present.
                        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                        when leaving only left side connected - again no voltages and no image.
                        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                        kept trying to block less pins on the left ribbon cable...
                        05-15-2024, 05:00 AM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
