LG 65UH5500-UA Backlight flash on first power up only
  • jason123
    replied
    Re: LG 65UH5500-UA Backlight flash on first power up only
    Stb is < 1 v when the connector is not plugged in. I believe the voltage is driven from main board on Stb. Post #20 is with everything connected. I just noted the large cap voltage when connected or not connected
    replied
    I look at your post #20:
    I took the measurements on CN2. The issue i see is the larger cap has 385V all the time, even when cable CN402 Is not connected... PFC circuit or what is suggested?
    STB is 3.4V,
    13.2v are 13.15 (when backlight is on), 12.6v when it doesn't turn on
    FAIL is 0.057
    80v are 77.8V
    But now you are saying that the STB is <1V when not connected.
    replied
    So if you have all the board connected, does STB pin of the power supply change state and TV is toggle on and OFF?
  • jason123
    replied
    No, just the power supply board connected to AC.. no other cables connected to the power board
    replied
    Originally posted by jason123
    The STB (PS-ON) has 0.017 V and the large caps have 384 V today
    Is that reading with all boards hooked up?
  • jason123
    replied
    replied
    The PFC boosted Voltage will be present when PS-ON is present, so check and see if the PS-ON is >2V when running the power supply board by itself, if it dies then it may have pull-up resistor for self test function on the PS-ON pin.
  • jason123
    replied
    Confirmed.. 385v is present with nothing but AC cable connected. The PFC is the TEA1716T from NXP
    replied
    with tv unplugged from outlet, unhook all connectors from powerboard, plug power cord back into outlet, see if you still have 385 with powerboard by itself.
  • jason123
    replied
    Would that cause the PFC circuit to stay on?
    replied
    That symptom described in first post seems like a faulty cap or a iffy solder joint, maybe try hitting your boards with a hairdryer when it's acting up, see if it changes any, heat any caps that could be the culprit, could be you have one that's just a little weak.
  • jason123
    replied
    STB is 3.4V,
    FAIL is 0.057
    80v are 77.8V
  • jason123
    replied
    Thanks.. ALL LED strips have been replaced with a brand new set - not used set. I used the upgraded set with adhesive tape - Identical to ShopJimmy
    replied
    Was just looking at jjanssen7's one here: https://www.badcaps.net/forum/showth...00+current+mod
  • jjanssen7
    replied
    That red note is interesting. $98 USD plus shipping and tax and the significant amount of labour to replace all the strips with upgraded ones means that lowering the current and replacing one or two strips is the only cost effective route for our purposes.
    replied
    Also talks here of a superior led: https://www.shopjimmy.com/lg-5835-w6...-strips-24.htm
    replied
    Check the note in red here: https://www.shopjimmy.com/lg-cov3369...wer-supply.htm
    replied
    Originally posted by jjanssen7
    I have worked on 6-7 of this model and each time replaced an LED strip that was bad. TV repaired, and then within days another strip failed and back to the blinking light on startup. After replacing a second strip, (with help from badcaps.net) I started to modify that LED driver board to send less current to the LED array, hoping to extend the life of the remaining backlights before they fail. Still testing at this point in the field, but none have come back.
    What I'm saying in your context is that the next LED strip may be on its way out. Will follow this thread!
    I think this is a good idea too.
  • jjanssen7
    replied
    replied
    Test CN402 also.
  • triplefour
    TCL 75S421 has sound but no backlight not even a flash
    by triplefour
    TCL 75S421
    PSU BOARD: 40-L402H8-PWD1CG
    it shows not even a flash of backlight when powering up.
    but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
    testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
    unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
    i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
    with mb connected, PSON...
    11-17-2023, 09:54 PM
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • ekozeko333
    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
    by ekozeko333
    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
    🔥 The Problem Started After Suspected ESD/PD Fault
    I experienced a power issue or ESD event through a USB-C charger
    After that, the NX20P5090 power switch was visibly burned and was replaced
    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • crozoki
    Philips 65PUS6554/12 one time backlight flash
    by crozoki
    Hello
    I have Philips 65" TV (65PUS6554/12).
    Problem is when turn on tv backlight flash only one time for about 1 second then turns off and display is dark but sound is there.
    Sometimes TV turns on and work with no problem, had backlight and picture, but mostly Tv wont turn on backlight. Any idea where to start looking?
    Power board TPV 715G9187-P01-008-001S
    Main Board 715G9907-M01-B03-005K...
    09-03-2022, 05:47 AM
