LG 55 UF6450-AU tv no audio,Flickering screen intermittent, not turning on.
  • Lisadk
    • Dec 2019
    • 8
    I have a Lg 55 uf6450-UA tv with no audio, no display, a flickering screen with a red light that blinking 3 times on the display when I power the unit on. This occurs temporarily when the tv has been unplugged for a while. The voltages on the power supply board at this time on p201 connector -pin1-3.3vdc pwr-on, pin 3-0 Grd, pin 5- 13.2,vdc pin 7-13.2vdc
    pin 9-0v Gnd, pin 11-3.4vdc. All the readings are steady on the connector.
    At the Test point 13.2v a steady 13.2vdcvolts. The voltages at P 801 the Led connector read LED+ 154vdc, LED-23vdc, led+ 319-346vdc not steady, led- 0v. I tested these points with the red positve lead & the black lead grounded to the chassis.
    I also checked the voltages on the Main board connector coming from the power supply board Pin 1- 3.3vdc. Pin 5 -13.3vdc. The Led on the Main board(near the orange sticker c2314) is lite while the Tv is powered on.
    The audio connector JK3800 no led lite is display.
    The flickering stops after turning the tv on and off a few time but the red light still blinks 3 times when turning on the tv. The only voltages that changed when the flickering stops on the power supply connector p201 DRV-ON pin 11- 0vdc and the p 801 connector LED+ 138 vdc, LED- 10vdc, led+ 138 vdc, led- 0vdc.
    I disconnected the P801 connector on the power supplyboard to the LEDS. The voltage on the power supply board LED+ 138vdc, LED- 0v, led+ 138vdc, led- 0vdc.
    In need of locating a schematic for Lg 55 uf6450-UA tv
    I think I have burnt out LEDs which is causing the incorrect voltages at the LED connector. I am not sure if repairing the LEDs will fix this TV since the main board is unavailable. Please help.
    Any advice would be greatly appreciated.
  • neilc6
    • Nov 2015
    • 1550
    Re: LG 55 UF6450-AU tv no audio,Flickering screen intermittent, not turning on.
    Yes it sounds like you have bad backlights. The led controller can detect under and over voltage conditions caused by shorted or open LEDs and shut down the backlight. Was just checking out this exact model since picking up a cracked screen one and it is edge lit. Flickering backlights, backlights flashing on at power up and no backlights are all symptoms of bad backlights.
    Edit: Looks like this model has main board issues as well. Make sure main board is sending BL-ON/DRV-ON signal https://www.badcaps.net/forum/showthread.php?t=60814
      "The voltages at P 801 the Led connector read LED+ 154vdc, LED-23vdc, led+ 319-346vdc not steady, led- 0v."
      OV reading on that Cathode return line means open circuit in the LED string, or bad linking connector between LED strip, or open wire, etc.
      • Lisadk
        • Dec 2019
        • 8
        Thank you for the advice..I will do my research on the led circuit and try to move forward on my repair.
        • Lisadk
          • Dec 2019
          • 8
          Replaced both 60 led bottom edge strips.part # 1536 WN6419 5 E 6916L2319A,
          1538 WN64195E 6916L2318A. Shopjimmy.
          Turned on Tv still flashing no display. Voltages at led connector.+155.6 v, -24.5 v, + 332 v, -3.5 v.
          Voltages at power supply connector p201 pin 1 3.36, pin 2 1.74,pin 3 0 Grd, pin4 13.28, pin 5 13.28, pin 6 13.28, pin 7 13.28, pin 8 13.28, pin 9 0 Grd, pin 10 0 Grd, pin 11 13.46, pin 12 1.74.
          I think it might be the Mainboard ...Sending it out Mainboard for repair.
          • jjanssen7
            • Nov 2012
            • 252
            mainboards are very common with that UF series and that 6450 Model...
            • Lisadk
              • Dec 2019
              • 8
              Update : I received the main board back from repair installed it and still the TV flickers on the when I turn it on but now the tv has a display on the screen of LG and displays flickers. The main board now has two red leds lit one on the right side of the board and the other is the audio connector.
              I order a power supply board since my power supply board making a buzzing noise sound like its coming from the transformer. Installed it today did not stop the flicking when I tuned it on.
              I am not sure what to do next. Please help.
              • Lisadk
                • Dec 2019
                • 8
                In search of a schematic LG 55 UF6450-UA
                  • 12206
                  • U.S.
                  Thinking that you still have the issue described in post #3, could be a bad connection in the backlight circuit or bad led/s.
                  • Lisadk
                    • Dec 2019
                    • 8
                    Posted copy
                    • Lisadk
                      • Dec 2019
                      • 8
                      Re: LG 55 UF6450-UA tv no audio,Flickering screen intermittent, not turning on.
                      Thank you for your response. What connection would you check in the backlight circuit? Do you think a component on the Display board is defective? (Picture attached )
                      I requested another set of LED strips under the warranty waiting for the parts & hoping that will fix my problem.
                      Thanks again for your advice.
                        • 12206
                        • U.S.
                        Maybe you did get a bad set, some testing there, lots more videos too, just need to sort thru them: https://www.youtube.com/watch?v=Bf5T2wwtydY
                        • Tomylee
                          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                          by Tomylee
                          Sorry for the person who’s going to read all this !
                          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                          07-11-2025, 11:52 AM
                        • 5mall5nail5
                          Help identifying connector for ASUS 4090 Strix RGB LED connector
                          by 5mall5nail5
                          Hi All -
                          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                          05-04-2025, 07:47 AM
                        • Nicktronic
                          Sony XBR-55X900F No picture, no sound no backlight
                          by Nicktronic
                          Hey,
                          I have this subject TV and when I plug it in I don't get a picture, backlight or sound. The remote and power buttons don't seem to do anything. I've metered the signals on the following after plugging in the TV;
                          Power Supply Board Connector CN6401 between PSU, MB, TCON
                          PIN 1 - BL_ERR - 0VDC
                          PIN 2 - BL-ON - 0VDC
                          PIN 3 - POWER_ON - 3.47VDC
                          PIN 4 - N/C
                          PIN 5 - STANDBY3.3V - 3.50VDC
                          PIN 6 - N/C
                          PIN 7 - GND - 0VDC
                          PIN 8 - GND - 0VDC
                          PIN 9 - N/C
                          PIN 10 - REG12 - 12.69VDC
                          PIN 11 -...
                          04-15-2023, 04:41 PM
                        • bussincaps
                          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                          by bussincaps
                          Hello All,
                          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                          08-03-2023, 12:57 PM
