Sharp Aquos LC-43CFE4142E only red light and won't turn on
  • L453R
    • Nov 2019
    This TV ran two months and suddenly without remarkable matters won't switch on again. Unfortunately the bill disappeared so Sharp refuses to provide the warranty... . Therefor I have to fool around with this scrappy device! But no time for tears - its an intersting excourse and a little bit of a personal challenge to me to solve this problem
    ...so, if power chord is plugged in only the red led is continiously on. I've tried all the different reset tips for Sharp models which Iwas able to find online. In all variations and even some random but logical possible combinations I could imagine. Spent a few hours without success.
    At the moment it seems that there is no lazy way to get it up running again. No offense, so now I drive on the heavy guns and I hope to be here at the right forum where the appropriate ammunition can be supplied by you.
    In preparation I opened the case and tried to measure the voltages. But the only point to measure I was able to find was the often mentioned possible cause pointing to this type of defect - the power supply for the backlight panel. At least I guess the plug named LED-Driver should it be, right?
    There was a DC of 59V - as I read the "Basic LCD monitors troubleshooting guides" from this forum thankfully created by Bud Martin, this is a way to high, isn't it?
    Okay, I took a few Fotos, tried to edit them a bit for the health of your eyes and hopefully you'll see immediatly what's to do next and could give me the right advices or instructions.
    Additional there should be mentioned that there is no sound like a click or so when the device is powered up. And the screen remains totally black, no flics or flacs, wheter I tried to reset with the known key combinations nor if i tried to update the firmware according to the method given by Sharp's hotline. Right in front I'm sure the built usb-stick was properly formatted and the firmware in the mandatory way correct placed on it -
    after all, I am an IT specialist.
    Sorry for the long text, when I got it right this detailed description is the desired form here in - so I'm very grateful that you read until here and in firm believing you can give me the infos I'm hoping for.
    Many greetings from Frankfurt in Germany
    L453R
    The pictures aren't dublettes - nearly on each I took a second one, slightly differed in perspective, so that something hidden or not really recognizable could stand out nevertheless.
  • CapLeaker
    Leaking Member
    • 8214
    Re: Sharp Aquos LC-43CFE4142E only red light and won't turn on
    Does the backlight turn on for a second, then turn off again, or does the TV just ignore everything and is stuck in STBY, bootup screen etc? Did you try to flashing the spi new firmware with a programmer yet? Check that the IR board is working.
    If that thing is stuck in STBY, I would take the SPI flash off the main board, read it and save the dump, erase (or FF) the flash, check that the flash is empty (indicates a bad SPI) then flash a working dump to the SPI, solder it back in and see what happens.
      • 12206
      • U.S.
      Check all the diodes.
        • 12206
        • U.S.
        Hard to tell from the pic. but D1 and C2 look like they could use some investigation to make sure they are alright.
          Can I see good clear pictures of the whole backside of the TV so I can see how all the boards are connected together?
          • scubacamper
            Sharp Aquos LC-70C6400U Half Screen Dark
            by scubacamper
            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
            05-03-2025, 12:19 PM
          • sefoster
            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
            by sefoster
            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
            11-20-2022, 09:29 AM
          • roy.zhero
            Sharp LC50LE752E no picture and backlight, indicator light is lit
            by roy.zhero
            I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
            When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
            When I hold the force-on-combination it will turn on. It then shows a perfect...
            09-20-2020, 01:57 PM
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            by sam_sam_sam
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
