LG 55LA6200 Back light strips
  • nomoresonys
    • 12272
    • U.S.
    Re: LG 55LA6200 Back light strips
    it seems like the replacement strips could be brighter, you could try using one of your lenses from original strip on one of the new ones and see if that makes a difference, in case the lenses might be different enough to be the problem.
    • neilc6
      • Nov 2015
      • 1550
      If the substitute lenses aren't a good match, they will not diffuse properly. Found this problem on a 42 LB set and trying a different seller. You can confirm by reinstalling an old strip if all the leds are working and the lenses are still attached.
      • andytv
        • Oct 2013
        • 19
        • canada
        Thanks nomoresonys and neilc6.
        Yes, did install one old working strip in the center along with new strips, no halo from the old but all new produce Halo. Did tried to use two old lenses on the new strips but wasn't a success. Tried to keep the .019 gap, no halo but instead a bright spot like if lenses had fallen. I guess it is hard to perfectly centre the lens over the LED and I don't see myself going through this 84 times. This morning got a hold of ShopJimmy, right now they just received new strips, they were BO and they do have black stand of hole instead of white, they assured me that no halo.
        • nomoresonys
          • 12272
          • U.S.
          for sure, would hate to do it 84 times.
          • alfatv
            • Sep 2020
            • 353
            All of Aliexpress backlights/lenses of that type are like that, at least I haven't seen anything better.
            For me the only solution that works perfectly is to use original backlights from TV with broken screen.
            Also even originals get blue tint over time because of yellow LED coating cracking. So replacing single LEDs may not produce good results as the new LEDs will be whiter than the rest.
            Next, LG backlights use both white and black glue. However the only ones with white glue have lenses falling off eventually.
            • andytv
              • Oct 2013
              • 19
              • canada
              #26
              Order the strips from ShopJimmy, I'll post back when they are installed.
              • nomoresonys
                • 12272
                • U.S.
                #27
                I'm sure shopjimmy doesn't make their own strips, there must be a more economical alternative, if they can buy them from china or wherever then so can we, not a huge deal but they mark them up at least 100%. I don't know where exactly, havent looked into it at all but will if I run into this problem.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • PNI E.
                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                  by PNI E.
                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                  02-20-2025, 08:36 AM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
                • h4rdw4re
                  Grundig 40VLE7131BF led strips doesn't light up
                  by h4rdw4re
                  Hi guys,
                  I have one very old TV.
                  Main problem I have with this tv is that led strips won't light.
                  I measured voltage levels, and inverter input is 24V.
                  other voltages are also ok.
                  What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
                  First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
                  I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how...
                  10-09-2022, 11:10 AM
                • lmcancu
                  RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                  by lmcancu
                  Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                  Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                  Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                  Instead of putting it back together I decided to replace...
                  04-01-2023, 01:11 PM
