Samsung Curved Screen
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    I have a totally dead Sammy Curved Screen set coming in today. Anything to look for out of the ordinary or is it just another LED set more prone to panel failure?
    TIA
    LJ
  • nomoresonys
    • 12328
    • U.S.
    Re: Samsung Curved Screen
    Totally dead, do a quick check of the diodes.
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      I assume you mean on the smps. Thanks, I will give them a check.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Totally dead is checking 5v standby on the powersupply if present it is probably the mainboard. LED failure is normally a error code on the tv.... ( blinking )
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          So follow my normal troubleshooting routine starting with all voltages on smps and go from there. Sounds like it's just another LED TV with a curved screen..Lol!!
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
          • Kiberge
            Samsung LH82QENELGC/EN Help needed - Static line on screen
            by Kiberge
            HI guys!
            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
            04-22-2024, 11:28 AM
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
