TCL 55S401 LED LCD TV no backlight
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    #41
    Re: TCL 55S401 LED LCD TV no backlight
    hi bud and beau i havent done any further testing busy with other things.. today though i brought tv in from garage and powered on and i can see the TCL logo light up for a fraction of a second and then backlight powers off (im thinking shutdown due to bad led) ... previously i tested outside and could not see this due to ambient light....so now i thinking that it is indeed a led issue and that this tv does not output power to the conne3ctor unless bacjklights plugged in and good...since replacing ps produced same results im pretty confident 99% that its bad LED which is what is normally the issue on most LCD LEd tvs when no backlight...the ps is typically not the issue.....in the old days with CCFL it was opposite..it was mostly ps/inverter issue and almost never lamp issue....most vifdeos have shown you shoyuld have voltage to the backlight connector even with backlights disconnected but apparently on this model that is not true since i have 0V with connector disconncted and yes bud maybe i was not testing the voltages at exact time in order to see the initital voltage(with BL connected) since its powering on only for a fraction of a second...all i do know is with connector disconnected to BL i have 0v and BL signal on.
    • shelby5041
      • Feb 2009
      • 1504
      #42
      update beau and bud
      BBBBBBBBBad news
      i reluctantly removed the lcd panel....since i have damaged several in the past
      it was indeed 1 bad LED strip..unfortunately during my swapping out etc trying to isolate the bad led i fried my power supply
      thats actually the not so bad news....even worse , i cracked the LCD panel while handling
      i hate removing lcd panels and may consider not doing it anymore as it wastes a lot of time and the risk just isnt worth it
      thanks for all your help
      • Cornito
        Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
        by Cornito
        Hello Team,
        I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
        Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
        Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
        08-08-2024, 08:09 AM
      • Cornito
        TCL 65C715 backlight issue
        by Cornito
        Hello team,
        I'm back with another topic.
        It's a 65C715 TCL tv with backlight issue.
        But the problem is a bit strange.
        When I took this tv from the marketplace backlight didn't work but picture was ok.
        Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
        Putting all back together the tv worked fine for weeks. => Contact issue??
        Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
        06-09-2024, 02:24 AM
      • fuzzyrunner
        Samsung LN52B750U1FXZA - Backlight Issue
        by fuzzyrunner
        Hello All!
        So here is the issue I am having. When everything is plugged in as normal, the TV turns on and I get a quick flash of the backlight. After that the backlight never turns back on but the rest of the TV works fine. If I pull the PWM pin from the cable between the main board and power board the backlight turns on and the tv works "normally". If it is plugged in I get nothing. I did do a factory reset but that didn't solve my issue. When everything is plugged in normally I get .6v at start up and continues rise over about 10 seconds. (~.6v then ~.8v then ~1.8v...
        02-28-2024, 07:36 PM
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
      • roman728
        iMAC A1418 Backlight issue
        by roman728
        Hello friends,
        I have this unit with no backlight on screen. After inspection i determined there is a shorted capacitor on BKL_BOOST circuit. I removed the capacitor, short is gone but backlight still not working. I found that Q9702 is not open and R9721 is only around 70kOhms but according to schematics it should be 301k. I removed the resistor and connected the gate of Q9702 directly to GND. Now i have 12v passing by the mosfet to turn on backlight IC LP8561 (U9700) but BKL_BOOST circuit is not working. I can measure only 12V there but it should be around 60V.
        Can you...
        04-10-2025, 11:48 AM
