Hitachi 32HXC01U - No Text in Menus
  • sickboy
    • Jun 2015
    • 86
    I obtained this TV with a backlight problem which I've fixed, only to find out that although the TV works fine, all menus are blank with no text.
    The background for the menu comes up with blank text boxes, and you can navigate these boxes with the remote, and I even managed to tune the TV in so the menu's do work, it's just that there's no text in them.
    Is there a way to factory reset the TV? I've tried menu 4725 but the TV just restarts when I do this. Any help greatly appreciated!
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Re: Hitachi 32HXC01U - No Text in Menus
    Hi.
    recovery firmware : https://yadi.sk/d/PpVl2B6RL2RKRA
    https://www.badcaps.net
    • sickboy
      • Jun 2015
      • 86
      Originally posted by arizanotlari
      Hi.
      Thank you very much kind sir, the TV is now working perfectly.
      Very much appreciated!
      • Electrotech68
        Hitachi C1421T-TEXT
        by Electrotech68
        Hi all im undertaking a repair of and old Hitachi tv model number C1421T-TEXT which has customer sentimental value .. the LOPTX has failed the type number on the label is DE50H0000152 which i believe is also HR7880 direct replacement . I have searched on google to no joy if anyone has any information to a remote possibility preferably within the uk to obtaining either the original or HR equivalent i would very much appreciate any help Many thanks guys Leo...
        01-31-2024, 02:49 PM
      • NYKing
        Hisense TV 32D33 - Replaced EEPROM, now menus have no text
        by NYKing
        The TV initially had a steady (not flashing) red standby light but did not turn on when power button was pressed. I tried all the usual “fixes” but nothing worked. TV would not turn on. After researching the issue, I concluded the cause was a bad EEPROM chip. I ordered the appropriate chip from ShopJimmy:
        https://www.shopjimmy.com/hisense-32...hoCOcUQAvD_BwE
        I took off the old chip using my hot air station and soldered on the new chip. I tested...
        10-07-2021, 05:06 PM
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • wolf1976
        hitachi 50hk5600 problem with display
        by wolf1976
        hi
        i have the above tv and the display starts distorts the display at only in applications like you tube
        after and on the didital channels
        now without connect the antenna only the image of itsselfs tv i have the image i have in attach
        i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
        can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
        09-13-2025, 02:26 PM
      • massimomax
        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
        by massimomax
        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
        spero che qualcuno può averlo per riprogrammare eprom. grazie
        Post in English !!!
        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
        02-28-2025, 07:27 AM
