Hi all im undertaking a repair of and old Hitachi tv model number C1421T-TEXT which has customer sentimental value .. the LOPTX has failed the type number on the label is DE50H0000152 which i believe is also HR7880 direct replacement . I have searched on google to no joy if anyone has any information to a remote possibility preferably within the uk to obtaining either the original or HR equivalent i would very much appreciate any help Many thanks guys Leo
Hitachi C1421T-TEXT
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by wolf1976hi
i have the above tv and the display starts distorts the display at only in applications like you tube
after and on the didital channels
now without connect the antenna only the image of itsselfs tv i have the image i have in attach
i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?... -
by massimomaxChiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
spero che qualcuno può averlo per riprogrammare eprom. grazie
Post in English !!!
I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
by dragometinTV Model: Hitachi 40HYC42
Power Supply: 17IPS71
MainBoard: 17MB95M
Panel: VES400UNDS-2D-NO3
When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
Is there any variants on 17IPS71 power supply's?
UART output pins 10 and 12 on scart connector:
Code:12:24:04.595
by sotodefonkHi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
I opened the tv to access the board and took the shared pictures of the T-Con board.
I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
Inspecting...2 Photos - Loading...
