Samsung LN-T5271F Faded white picture then works fine
  • Brucetafer
    • Jun 2018
    • 133
    As stated, when you power it on, everything works as should, but picture is faded white, then after a couple minutes it works fine, then goes back to faded instantly.. its pretty much instant change back and forth after a couple minutes.. ive narrowed it down to either Tcon or the FRC.. which should I order? ive tested all voltages and they are in spec, but don't have any information on testing the FRC or TCON voltages or outputs.. I don't have a scope..
    Re: Samsung LN-T5271F Faded white picture then works fine
    So the GAMMA Voltages all stay the same when pictures faded?
    • Brucetafer
      • Jun 2018
      • 133
      I don't know where that test point is.. Ill look now. I was referring to the power supply voltages stated on the board..
        Gamma Voltage test points are on the T-CON board.
        You should also upload the screen shot of the screen and also the boards and the whole back side of the TV showing all the boards.
        • CapLeaker
          Dell ATX PSU won’t start, but forcing it works fine?
          by CapLeaker
          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
          10-28-2024, 06:59 PM
        • kamiewtype
          MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
          by kamiewtype
          I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
          The specs are:
          MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
          Intel core i9-10900kf
          2x16gb Corsair Vengeance kit
          BIOS ver is E7D06IMS.1B0, from 6/12/2023
          The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
          I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
          11-01-2024, 10:52 AM
        • edugimeno
          TD Systems K50DLP8F works fine on 1 HDMI, bad on others
          by edugimeno
          I have this TV set that I spent a long time fixing it.
          I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
          I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
          I didn't use that TV much at that time. Now that I'm using it,...
          10-06-2023, 03:00 PM
        • marce002
          Macbook A1465 works fine Linux but turns off in MacOS
          by marce002
          Hello
          I have this macbook Air 11 inch, was working fine with macos,,, then suddenly turns off by itself after apple logo screen.....it cant boot...
          Formating and installing does not work because it also turns off.....
          But: booting linux ubuntu from pendrive and also installing it in ssd works fine!! hours and hours, the macbook runs fine and fast and cool....
          So she does not like MacOS , loves Linux... can this be related to EFI? I have tried booting macos with shift pressed and allow me to login but even in this safe mode it turns off itself with...
          02-02-2022, 05:43 PM
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
