Hitachi L40A105A Bad Picture
  • billydanger
    • Feb 2014
    • 15
    I have a Hitachi L40A105A with a bad picture. My bet is the mainboard but I don't want to invest the $ in a new one (if I can find one) without some input from the experts.
    I have photos of the power supply and mainboard as well as the powered up TV with and without an HDMI signal. I did not take photos of the inverter boards since the backlight seems to be ok. I can provide those if necessary.
    If I leave the unit running for a while the picture will sometimes come in clearly for about 30 minutes or so.
    Soldering is not a problem for me if necessary.
  • CapLeaker
    Leaking Member
    • 8324
    Re: Hitachi L40A105A Bad Picture
    looks like tab bonds to me
      • 12269
      • U.S.
      Is that capacitor there by where it says Pb Free flat on top? Looks like it's bulging a little, might just be an optical illusion.
        Can we see the pictures of the whole backside of the TV? Right now I cannot tell if the TV has discrete T-CON board of integrated T-CON board.
        Is the Tab bonding board on the bottom edge of the LCD panel?
        What is the history of the TV?
        • billydanger
          • Feb 2014
          • 15
          Capacitor is not bulging. Optical delusion!
          Thanks for the reply.
          • billydanger
            • Feb 2014
            • 15
            Photos of the integrated T-Con are shown. I have one shot that has the entire strip and three close-up shots of the Left, Center, and Right sections that can be pasted together for the whole thing if needed.
            No amount of wiggling the flexboard connectors or the mainboard connector produce any change in the picture, either good or bad. I also used a heat gun up and down the T-Con board and the screen edges (VERY gentle heat) and also saw no changes.
            Am I correct in assuming that the T-Con cannot be replaced without replacing the entire screen/T-con assembly?
            Thanks to all of you for the replies.
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • PNI E.
              firmware hitachi 50hk6000 mainboard 17mb130s
              by PNI E.
              hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
              02-14-2025, 02:06 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
