Re: Sharp LC-70SQ15 PWB DPS-206EP problem
there was no need to remove it..
I mean D7216 if i see well..Leave a comment:
So some points I'm gonna cover is:
Voltage tests on LED pins
Voltage peak on LED pins when tv is turned on
Returned voltage on each strip
PMW effect of multimeter probe when testing pin 5/6 on LED driverLeave a comment:
Rs is less than 1ohm, don't know how much. Yes i have forgot you have a boosted tension for an instant, have you tested the power diode? It is maybe that one in TO220..Leave a comment:
Q7201 is for the boost converter and you DO HAVE 268V per your post #17 LED boosted Voltage, PWM Controlled Q7202 is the one that is not getting the drive to turn it on.
So are you saying now that you no longer have LED boosted Voltage?Last edited by budm; 09-28-2019, 02:34 PM.Leave a comment:
I agree with you, I appreciate your answer, do you know some technique to check if it has the right values?, for Rs just by reading the number, but in the other componentsLeave a comment:
Hi, you have changed Q7201, but if it was failed also the Rs will be failed, that one connected to pin 11 CS of the IC and to the source of Q7201.Leave a comment:
The Backligts can be dimmed by ADIM (Analog dimming control by varying the DC level), the PWM1 and 2 are for the Pulse Width Modulation dimming scheme by varying the pulse width, it will be setup for one or the other, not both. Most TV use PWM Dimming control. You board uses the word DIMMER and you do have >3V that DIMMER pin of the PD pin, so this one may be using Analog dimmer setup.
Just in caseLeave a comment:
Well, this is not going good, I did changed the MOSFETs and still is in black.
Still have 0v on DIMOUT not even a peak when I plug to AC, now I'm really lost.
Ok but now something weird happened, when I connect my positive probe to
PWM1 or PWM2 the LED's turned ON, well that's a progress I guess, but I thought that the driver DIMOUT was controlled by ADIMM, and Why is this happening, I've attached some pictures, you can see the backlight through the holes
Can I hook up everything to test it out?Leave a comment:
MOSFET Q7201 is for boost converter circuit as explained before and it is OK otherwise you will not have that Boosted Voltage so I do not understand why you replace that one.Last edited by budm; 09-24-2019, 09:18 PM.Leave a comment:
"Also no continuity between gate and S on any direction"
It is MOSFET, that is why.
https://www.elprocus.com/mosfet-as-a...free-circuits/
No Gate drive for the MOSFET may mean the IC is bad or something is locking out the drive output.
I will replace them an tell you what happendLeave a comment:
No Gate drive for the MOSFET may mean the IC is bad or something is locking out the drive output.Leave a comment:
At this point, it looks like the Boost converter is working but the Q7202 is not getting the DIMOUT (pin 11) drive of the BD9488 to drive the Gate to turn that MOSFET on and off to allow the LED current to flow. Check the resistance between GND and the DIMOUT pin to see if it shows low resistance reading or not. You should also test R7299 (connected to pin 11) and also the resistor connected to the Gate of Q7202, also check Q7202 itself.
The resistor to the gate R7231 labeled as 2.49k seem ok, with 2.47k
I couldn't find the R7299 I'm assuming you are talking of the jumper resistance R7229, have 0 as labeled
Some days ago I removed the MOSFET to test it out, and couldn't find any faults, but just to double check I removed it again, I've attached the readings. Also no continuity between gate and S on any directionLast edited by rabitbay; 09-24-2019, 12:42 PM.Leave a comment:
At this point, it looks like the Boost converter is working but the Q7202 is not getting the DIMOUT (pin 11) drive of the BD9488 to drive the Gate to turn that MOSFET on and off to allow the LED current to flow. Check the resistance between GND and the DIMOUT pin to see if it shows low resistance reading or not. You should also test R7299 (connected to pin 11) and also the resistor connected to the Gate of Q7202, also check Q7202 itself.Leave a comment:
Just to avoid any bad reading, I just changed my multimeter batteries for new ones this morning and double checked, I did had the same readings.Leave a comment:
So just to be clear, right now when you power up the board you DO NOT see the backlights flash on for seconds, correct?
You are also seeing over 200V on all four LED + each time you power up the board, correct?
BTW, 418VDC on the main filter caps is too high, it should have cause the PFC circuit to go into shutdown. Main caps are only rated at 450VDC. Are the batteries for your meter good? Low meter's batteries will cause the reading to be higher than it should be.Last edited by budm; 09-23-2019, 09:09 PM.Leave a comment:
by edugimenoHi There!
I'm trying to help my friend who owns a restaurant be just bought.
He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
It's stuck using, I guess, the 2 sided tape that comes with the strip
The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth... -
by adelageHi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
I know that the best solution would be to get a voltage... -
by benareenoI wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
I have an adjustable dc power supply and was trying around 9 volts.
I have a pic of a single diode...where to put pos and neg terminals to light it up?
Pic of middle of strip..is this where i light the entire strip?
And pic of end...or does this light the entire strip?
Where to put pos and neg for single diode..multiple diodes and the entire... -
by mikey5791Hi,
Got this working ips led monitor by the brand of
Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...-
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... - Loading...
