sony KDL-50W808c audio ok but no video
  • ccaguest
    • Sep 2019
    • 4
    • Italy
    Hi friends,
    i'm struggling with sony KDL-50W808c with , but no dark screen.
    If i unplug the right lvds cable form t con ( i have 2 lvds from t con to panel )half screen is ok.
    As soon as i connect back the right lvds, i realized that all tcon voltage voltage in the way of panel goes to 0 and then dark screen.
    i have changed the tcon with same result.
    Tcon is auo T550HVN08.2.
    I would like to check for short on the card that distribuite voltage from lvds to cof flat , i but know where to measure .
    Any help or drawings or idea will be really apprettiate
    • 12330
    • U.S.
    Re: sony KDL-50W808c audio ok but no video
    Check those little caps there, TV UNPLUGGED from power, ohm mode, probably looking for shorted or very low ohm could be a problem.
    • ccaguest
      • Sep 2019
      • 4
      • Italy
      Tkx for reply,i checked and removed several suspicious caps ( low resistance vs gnd ) but none helps.looks like same common tracks drain to ground .
        https://www.badcaps.net/forum/attach...7&d=1567854486
        So you check the cap on that tab bonding and found some low Ohm readings on some the cap? Then if you check the resistance of the empty pads where the caps are connected to, does it still show low resistance? It may be that the COF may be bad.
        • ccaguest
          • Sep 2019
          • 4
          • Italy
          Well, i have 3 cof in the rx part of the screen.i cant say that low resistenze is evident close to one specific cof tab. would say not full short.
          I eould try to go with power supply to check for short.but i dont know were to go with the power.schematic would help.
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • Daren87
            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
            by Daren87
            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
            08-13-2023, 03:25 PM
          • iglitare
            by iglitare
            09-04-2025, 07:13 AM
          • rimwall
            Sony KD-65x7500D - double image - Tcon or Panel?
            by rimwall
            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
            11-18-2025, 02:09 AM
          • thelankanguy
            Sony KD-55X9000F TCON Issue
            by thelankanguy
            The TV shows a black screen with no image.
            TCON ribbon connectors were disconnected individually for image and there was no half image even.
            Later both ribbons were disconnected and TCON voltages were tested.
            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
            There is also a short to ground in this circled inductor.
            Is this a TCON issue or something else ?...
            12-13-2024, 12:27 AM
