Sony KD-55X8509C – No Backlight
  • birchy7
    • Mar 2018
    • 25
    Hi, I have taken this TV on against my better judgement,
    It was left in for repair at our local repair shop with the following history.
    Tv powers on, s/by led flashes green & amber for approx 30secs then goes to a solid white.
    You can stop the green/amber flashing earlier if you turn tv on with remote or side power button, this brings you straight to a solid white lit led,
    Nothing appears on screen, no backlight lit or no image shows when shining torch at screen, there is some audio when I select menu, source etc on remote control, so I guess tv has powered on.
    The chap said he replaced the main board (B), then carried out a USB update, this resulted in the TV now just remaining powerless with the s/by led blinking with 1 red light every 30secs, the optical audio socket is not lit on the main board as it was before.
    He gave up on the TV and now I have it in front of me, I was able to get a working replacement main board & have fitted it, the results I now get is the exact same as we had before it went into the repair shop, still no backlight or no dark image.
    Quick checks on voltages on power supply show all is well methinks, the voltage to the LED strips sits at 64volts on connection CN6801, I expect this should be much higher?
    I have no service sheet for this so any helps would be much appreciated.
  • birchy7
    • Mar 2018
    • 25
    Re: Sony KD-55X8509C – No Backlight
    hi, had another quick look at this tv on my lunch,
    I tried doing the power/v- reset,
    I held the 2 buttons in & powered on with plug,
    All i get is the green/amber flashing for approx 30secs, then light goes out, no green led.
    I will take all voltages and post them here later this evening.
    cheers
    I have not done a usb update yet incase it bricks the main board as with what happened in the repair shop.
    • nomoresonys
      • 12114
      • U.S.
      Green/amber usually indicates a software problem, I would check and see if there was any problems reported with the current one availabe at sony UK, if not try an install, a firmware update is always recommended after a mainboard replacement.
      • birchy7
        • Mar 2018
        • 25
        hi, i've been tempted with doing the usb update, just kinda put of after the repair shop seemed to have bricked the orginal main board with update,
        I contacted the repair guy & compared the update file, his & the 1 on sonys website are the same...
        shall i go forth & do the update.....lol
        • nomoresonys
          • 12114
          • U.S.
          Damn good question, I would check real thoroughly to make sure that update isn't buggy, wonder how long it has been out. Possibly buggy firmware is why I never set my tvs to auto update.
          • nomoresonys
            • 12114
            • U.S.
            I did run across this, not sure if it pertains to your tv but it does have to do with Android tvs: https://www.forbes.com/sites/johnarc.../#50c2c08b4741
            • birchy7
              • Mar 2018
              • 25
              cheers for that, intrestinging read, i could live with this tv here giving out a loud beep now and again..lol beats what i'm getting from it now haha
              • shahnld
                Sony kdl 65xg9505 green amber blinking
                by shahnld
                Good Day.
                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                01-03-2024, 03:05 PM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • DKWS89
                Sony XBR 49x900E - Sound and backlight on but no picture
                by DKWS89
                Hey Guys,
                So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                12-14-2023, 04:30 PM
