Samsung UE55H6200 Sound but no video display
  • Nix125
    replied
    Re: Samsung UE55H6200 Sound but no video display
    Hi all thanks for the info. I will take a look later when back from work.
    replied
    This is interesting, if you could fix your tcon, you would have a spare.
    replied
    1) There is at least 1 LED that I see, LED3_AVDD next to RD02 component. I expect this LED to come on if the boosted AVDD Voltage is present.
    2) I see VGH and VCOM test points close to IC U0205.
    3) I see V12 test point next to inductor L202.
    4) What is the P/N of U0201?
    I cannot see the rest of the test points due to poor picture that is not on focus.
    You need to take hi-res straight shot of the whole T-CON board.
  • budwich
    replied
    Originally posted by Nix125
    Hey nomoresonys I can see VGHC, VGL and VGB12 on the TCOM board is this the pads to check. I have a multimeter what am I checking for? Thanks
    good question but probably not important. The reason being, is just measure and post the results. The "wrong voltage" will usually standout... low, high or otherwise. You aren't looking for an absolute value at this point.
    further, the labeling isn't going to be "exact" for all set and hence look for things like "VXXX" or so as potential points of interest. As budm has indicated, those that he listed are a good "type" to look for.
  • Nix125
    replied
    �� lol were see if the Tcom board I ordered will fix the tv should arrive late next week.
    replied
    Damn if I know, I was trying to learn what they should read myself.
  • Nix125
    replied
    replied
    Did you test those three spots in Buds post #14? VGH
    VCOM
    V12
  • Nix125
    replied
    Hi nomoresonys thanks for the links on ebay I checked them out a few days ago hopefully tcon board will fix the issue. Dudm we tried with and without the lcd connect which made no difference. There is no led on the tcon board?
    Many thanks
    replied
    https://www.badcaps.net/forum/attach...2&d=1566036467
    Check: with and without ribbon cables between the LCD panel connected. Do not disconnect and re-connect any cables when TV is plugged into the outlet.
    VGH
    VCOM
    V12
    Does LED3_AVDD light up when TV is turned on?
    replied
    Just in case it can't be fixed, list there, the first one has a bit different numbers think I would skip that one, but from 2 down a ways look like a match, they seem to have a bunch of them, they also have a make offer option: https://www.ebay.co.uk/sch/i.html?_f...vn05.7&_sop=15
    replied
    One there that seems to be a match: https://www.ebay.co.uk/itm/5555T10C0...UAAOSw2QtdJ2za
    replied
    See the labels vgb 14, vgb13 etc, and the little round copper looking pads, there's like 28 or so, those are test points but I don't know what voltage they should be.
  • Nix125
    replied
    Thanks for looking nomoresonys. Take a look at my attachment you should be able to zoom up as its decent resolution?
    replied
    To be honest I have trouble knowing what the voltages should be, haven't had to deal with them very often, well lets see which one you have, what are the first 10 letter/numbers on your white sticker? Should start with bn-96xxx.
  • Nix125
    replied
    Thanks for the reply do you have any guidence on how to test?
    replied
    It is looking like a faulty tcon, I would try one if they're not to expensive, tcon can be tested, how to test can be confusing tho if not clearly marked.
  • Nix125
    replied
    Hi neilc6, I've tried disconnecting the ribbon cables one at a time and have the same issue. It seems that as soon as the t con board is connected the leds go out even with no ribbons connected to the LCDs. There are no lights built onto the tcon board. Could it be a faulty tcon board?
  • neilc6
    replied
    Disconnect ribbon cables (unplugged) one at a time and see if you get a picture.
    https://www.badcaps.net/forum/showthread.php?t=50646
  • Nix125
    replied
    Ok so when I disconnect the power board from the main board I can see the LEDs light up from the holes behind. Coincidentally it seems that if I keep the power connect to the main board and disconnect the tcon board the LEDs do light up. What can you make from this?
    Kind regards
  • FourRunner
    Display issue Samsung TV UA65JS9000W
    by FourRunner
    I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
    10-03-2024, 07:05 PM
  • arctor
    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
    by arctor
    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
    04-26-2025, 05:22 AM
  • Kjell
    Samsung Series 9 - BIOS issue
    by Kjell
    After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
    Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
    08-01-2025, 09:15 AM
  • alro7779
    Samsung UN55MU6103F video problem; has colored stripes on the display
    by alro7779
    Hello, everyone!
    A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
    09-27-2025, 11:29 PM
    Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
    This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...
    09-06-2024, 10:20 PM
