Samsung UE55H6200 Sound but no video display
    Re: Samsung UE55H6200 Sound but no video display
    1) There is at least 1 LED that I see, LED3_AVDD next to RD02 component. I expect this LED to come on if the boosted AVDD Voltage is present.
    2) I see VGH and VCOM test points close to IC U0205.
    3) I see V12 test point next to inductor L202.
    4) What is the P/N of U0201?
    I cannot see the rest of the test points due to poor picture that is not on focus.
    You need to take hi-res straight shot of the whole T-CON board.
    • nomoresonys
      • 12229
      • U.S.
      This is interesting, if you could fix your tcon, you would have a spare.
      • Nix125
        • Aug 2019
        • 25
        • Uk
        Hi all thanks for the info. I will take a look later when back from work.
        • Nix125
          • Aug 2019
          • 25
          • Uk
          Ok so received a second hand tcom board today that I purchased from ebay for 11 quid delivered. When I connected it up and turned on the power three blue leds lite up then a noise that sounded like a hdd booting could he heard and the tv is now working perfectly. Didn't realise that the board had lights as the broken one none lite up.
          Thanks for all the useful information appreciate your help.
          What a great forum to be part of.
          Kind Regards
          Nick
          • nomoresonys
            • 12229
            • U.S.
            Glad to hear it.
              Kind Regards
              Nick
              Thanks for the follow-up.
              • Nix125
                • Aug 2019
                • 25
                • Uk
                #27
                Particular thanks to nomoresonys and dudm for being extremely helpful and polite.
                Thanks Guys.
                • nomoresonys
                  • 12229
                  • U.S.
                  #28
                  I appreciate it, was painless, it's always fun to help nice people that respond in a timely manner as you did, some take a couple weeks in between posts. By that time I've forgotten what the details even were.
                  • Nix125
                    • Aug 2019
                    • 25
                    • Uk
                    #29
                    Hello again all. An update to the tcon board I fitted a while ago it appears that when I turn the device on in the mornings all works as it should but when I turn the device off then shortly later turn it back on I encounter the same issue as described in the initial post. If I leave the device off for a considerable amount of hours and turn back on it works again, perhaps when just cold. Question is, is this a faulty tcon boad or perhaps a power board. The light on the tcon does not turn on when this happens and you can hear audio. Any assistance would be greatly appreciated. Thanks
                    • nomoresonys
                      • 12229
                      • U.S.
                      #30
                      Try a firmware update, wondering if it's an eeprom issue.
                      • nomoresonys
                        • 12229
                        • U.S.
                        #31
                        Maybe try a factory reset.
                        • Nix125
                          • Aug 2019
                          • 25
                          • Uk
                          #32
                          Hi nomoresonys, yea good shout I'll give both ideas a go when the TV starts working again. Cheers
                          • nomoresonys
                            • 12229
                            • U.S.
                            #33
                            Easy little reset that might work: Disconnect the power cord from the outlet, press and hold the power button on the TV (not the remote), for at about 20 seconds. Then wait a few minutes and plug the TV back in and press power once.
                            • Nix125
                              • Aug 2019
                              • 25
                              • Uk
                              #34
                              Just tried the above and didn't work so will wait until tv works again and perform a firmware update and factory reset
                              • nomoresonys
                                • 12229
                                • U.S.
                                #35
                                Ran across this, seems it says don't update to latest firmware if you want to use their process/hacks: https://wiki.samygo.tv/index.php?title=Main_Page
                                • nomoresonys
                                  • 12229
                                  • U.S.
                                  #36
                                  There's eeprom resets there BUT I didn't see model H on the list, usually involves: with tv unplugged, short pins 5 and 6 with a wire-plug tv in turn on for 20 seconds-turn tv off, remove wire, something to that effect.
                                  • nomoresonys
                                    • 12229
                                    • U.S.
                                    #37
                                    Here he's resetting a D5700, I couldn't find one in English, hell if I know why, it's a pretty popular language:https://www.youtube.com/watch?v=DDzOSdfA41s
                                    • Nix125
                                      • Aug 2019
                                      • 25
                                      • Uk
                                      #38
                                      Boom fixed!! Thanks for you help again nomoresonys. I updated the firmware and still had the issue so reset all settings which fixed the issue. I didn't think such a simple action would have such an effect
                                      • nomoresonys
                                        • 12229
                                        • U.S.
                                        #39
                                        Glad to hear it.
                                        • Nix125
                                          • Aug 2019
                                          • 25
                                          • Uk
                                          #40
                                          Ah dam seems to be happening again now even after resetting the device. Seems to work if left for around 6 hours then when tuning off on same issue happens. Any ideas? Thank you
