Hello all, I'm working on a lg 43" LCD. When it's plugged in , the red light fades in and out twice an then stays off. When the power button is pressed, the red light stays on. When pressed again, red light goes out and backlight seems to flicker a bit, but never comes on. I have checked the voltages on the power supply, 3.25 at per on, 3.45 at pdim, 3.45 at n.c. 23.3v at the 24v pin, 12.03 at the 12v pins. The voltage to the LEDs jumps around between 60 and 75 volts, which is where I think the problem is. What should I look for next? I have tested all the smaller caps, and the seem to be ok.
Lg 42ln5300 tv won't turn on. Power supply might be ok?
Re: Lg 42ln5300 tv won't turn on. Power supply might be ok?
LN series known for bad backlights. Get an LED tester or just replace all of them. If you plug it in with the panel off, you should be able to see which strips are out when they flash on before shutting down in protection mode. Lower backlight level to 60 after repair and do it for all inputs. -
$30 for new strips
https://ebay.us/MZQDZeComment
Hi I’m having similar issue except with mine after the standby light blinks twice and fades out. It never stays on and no response from power button.
I have all voltages and at led connector it’s steady at 125v at the + side and 20v at the negative side. If I unplug the led connector the + side still same at 125v but 0v at the negative side. Led strip issue?Comment
Hi I'm having similar issue except with mine after the standby light blinks twice and fades out. It never stays on and no response from power button.
I have all voltages and at led connector it's steady at 125v at the + side and 20v at the negative side. If I unplug the led connector the + side still same at 125v but 0v at the negative side. Led strip issue?
Can you confirm the SMPS board number you have on your TV? Doing a quick search on shopjimmy, I'm going to assume your TV has SMPS board model number EAX64905301.
Do you see the backlights flicker at all when you initially plugin/turn on the TV? You should be able to look at the metal chassis holes and see if it illuminates - even for a split second.
The LED string is wired in series - you can see this if you look at the back of the SMPS board @ Connector P801. The middle two pins are connected to each other.
Are you measuring the voltage from VLED+ to VLED-? Or referenced to ground? Given that you read +125V, my guess is that you have at least one open LED. Do you have an LED tester? Might be time to open up the panel and have a look for blown LEDs.
Do you get the proper voltages on the connector from the SMPS to the main board?-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.Comment
So I originally thought I had a bad led or two and disassembled the tv to get to them. Testing each showed they all worked. I then found out that the mainboard was faulty at the microprocessor.
I found an exact replacement on eBay cheap which I purchased. Now with the new one I have different symptoms. No flashing led light, no light at all actually and the only voltages I measure now are the two 3.3v.
With my original mainboard I get all voltages 3.3v 3.3v 12v 12v and 24v. No backlight flicker at all with either mainboards. Possible I purchased a faulty mainboard?
In regards to testing LED voltages I measured referenced to chasis ground. Should I measure at led + and led - instead?Comment
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
Assuming...7 Photos -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by CMCMHello Everybody,
Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
The outputs marked 12v and 20v are all measuring only 1v.
The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
The capacitors physically look clean (no bludgesor leaks) and... -
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
