Sony KDL-40W2000 3 LED Blnks Error
  • StephenU
    replied
    Re: Sony KDL-40W2000 3 LED Blnks Error
    Hi all many thanks for the input my findings are as follows:
    I get all CN6200 voltages when TV relay clicks to try and turn on after that the relay clicks and goes off I'm sure as all voltages start dropping significantly apart from 3v3 standby.
    If I disconnect all connectors from PSU no relay click at all, something is causing the fault other than the psu I think.
    I can't get a reading from the IC as it cuts to the error mode too quick.
    Hope that makes sense, I think it's related to the main board as I get the same values with Tcon disconnected, something is triggering the 3 blink error.
    Thanks guys.
    S.
    replied
    The one I read said if you do have the standby then it's the mainboard at fault.
    replied
    Thanks, just post in here in the forum, that is what this open forum is all about, learning and understanding.
  • Diah
    replied
    for record this is not first time i discusses this over here... before i did on Toshiba with some one from UK. and i leaved the answer to the owner of the thread .. and here i will do it again you can write me i will do my best to answer what i know.
    replied
    Originally posted by Diah
    LOL TV are built on Linux 100%
    So? Which pin of the IC6100 grounded out the 3.3V power supply, simple?
  • Diah
    replied
    replied
    What DOES the LINUX has to do with the device grounding out the 3.3V that you indicted when the device has no connection to the 3.3V?
  • Diah
    replied
    Originally posted by budm
    I am trying to understand how the 3.3V is grounded by the IC6100 and caused 3-blink as you indicated and not going by the service manual, is it that hard to explain? IC6001 has no connection to the 3.3V power supply line so how does it ground that out?
    budm ... this cant be explained if you don't know the basic of Linux script code.
    you can start to explain how does error code generated and redisplayed on front indicator.. which part over all TV are Premiere one PSU or MB??
    replied
  • Diah
    replied
    "when 3.3V went grounded via IC6100 there other line continue feed the set to register error." How does IC6100 ground out the 3.3V? I do not see how IC6100 will ground out the 3.3V, I do not see 3.3v supply line connected to IC6100.
    do you want to learn or to make point... i am here also to learn from points i didn't face before... did you know about what i wrote (script) how it work on SMPS or SPI... what does it mean at TV platform since 80th .. sorry to say if some one don't know any about this stop make conflict between stand alone hardware and dual one.
    i leave it to OP come to result.
    replied
    this UNIT are dual IC made ONLY by Sony self as SPI and SMPS. it had script run on and off too
  • Diah
    replied
    replied
    SM manual page 60.
    So how does 3,3V STBY is grounded via IC6100? So you are saying the SMPS IC6100 (for the +18v, +15v, +10.5V, and +33V) is bad?
    I do not see STBY 3.3V feed the IC6100 which is in the HOT side.
  • Diah
    replied
    look on the photo OP posted PSU 18 legs IC
    replied
    Which board and at what page of the service manual IC6100 located?
  • Diah
    replied
    wrong
    3 error blink very wide at Sony platform not all listed on service manual are the case.. when 3.3V went grounded via IC6100 there other line continue feed the set to register error. this is from experience not SM.
    replied
    Service manual:
    https://www.manualslib.com/download/...l-40w2000.html
    Error code 3-blink:
    3 ) UNREG10.5V, PANEL5V Voltage Trouble (DCALERT
    So perform test as RJ suggested.
  • R_J
    replied
    There may be a problem with the panel, check if you have +5v on the t-con, Also disconnect the lvds cable between the t-con and the main and see if you get the same error.
    replied
    Originally posted by R_J
    If you are getting the led on the front of the tv and you here the relay click when you press the power button, you MUST have STBY3.3V. Check for the STBY on L6300 It will be there.
    If you had an older SONY CRT you WOULD find these parts. This has NOTHING to do with this LCD tv. got to love the internet
    +1, no way you can have blinking LED if the STBY 3.3V is not present.
  • R_J
    replied
    This is also a problem in the power supply circuit, check T603 and R672. (I cannot find these parts on the schematics at all most parts have the letter of the component and then 4 numbers.) ""
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • jchon
    Sony A1e 5-blinks help
    by jchon
    Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
    I found the service manual, which was critical to know where to probe.
    https://www.manualslib.com/manual/20...1e-Series.html
    With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
    Unfortunately the 5-blinks...
    06-28-2023, 11:52 AM
  • Nicktronic
    Sony XBR-65X850D 2 Red Blinks
    by Nicktronic
    I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
    Any Sony experts out there that can help??...
    11-19-2023, 06:51 AM
  • dumbdd
    Sony 75X9400E TV.. 5 Red blinks
    by dumbdd
    I was using this TV for 5 years before it stopped working. I like this TV and would love to fix it myself.*
    When I press the power button, the white led comes on (sony calls the module smart core) and then it switches over to 5 red blinks. No screen, no backlight, no relay click, nothing. I have disassembled the tv and found the service manual for 75x940e online. The manual suggests a faulty power board, TCON or the panel.**
    The standby pin is at 3.3V. Fuses on the mainboard and TCON are fine. Caps on TCON also seem to be fine. When I turn on the tv the white led...
    07-01-2023, 08:54 PM
  • Nicktronic
    Sony XR-55X90J 4 blinks
    by Nicktronic
    Hey guys, got this Sony that turns on momentarily and then goes black with 4 blinks of the standby light. I can't find a service manual, but best guess was the Local Dimming board based on a similar TV saying LD_ERR or BCM_ERR. I found a replacement, but it didn't work. Before I put more money into replacement boards, Im wondering if anybody has seen this issue and what worked for them, or has the service manual for this specific TV.
    Thanks!...
    02-13-2024, 07:01 PM
