Samsung LN40B500P3FXZA HDMI LOOSE, MAIN BD.QUESTION
    A neighbors TV, Kids switched Dvd player, Game Console, etc. to HDMI Ports, this tv only has 2 ports that I could see. both HDMI ports are loose and inoperative. not sure if I can pull the main board and re-solder them. TV is in use and wall mounted.. this TV has Version SQ01 on the sticker on the back along with the model and serial number.
    when looking at used Main boards on Ebay, I see some listed under the Samsung Model number and version SQ02 for sale, but none for version SQ01, I am not sure if they interchange and don't really want to disassemble the tv to look at the Main board part # sticker on the board itself...I think my neighbor wants to order a replacement main board so I can swap it out for him and that will fix the HDMI problem. I see ShopJimmy shows 2 different boards but they say to look at the white sticker on the board for the part number. does anyone know if there's a difference between models with versions SQ01 and SQ02 ? Thanks.
    Re: Samsung LN40B500P3FXZA HDMI LOOSE, MAIN BD.QUESTION
    well, I guess you answered the question yourself. Either you solder some new hdmi ports to the old main board, or replace the main board. Yes, the version of the main board does matter, since it could be that the other version has a different panel, or something else.
      Thanks for the reply, I Appreciate it.
          Thinking that both those boards on shopjimmy will work, should really match sticker numbers to be sure, one has a Y and one has a K at the end but they both work.
            They likely have different main boards to match different panels which may or may not be interchangeable, Look at the LVDS connectors and you will see they are slightly different
              https://www.shopjimmy.com/catalogsea...LN40B500P3FXZA
                Okay, we will remove the back to access the board and get the actual part number off the Sticker to be safe. Thanks.
