Samsung LN40B500P3FXZA HDMI LOOSE, MAIN BD.QUESTION
  • MisterD
    • Oct 2012
    • 668
    A neighbors TV, Kids switched Dvd player, Game Console, etc. to HDMI Ports, this tv only has 2 ports that I could see. both HDMI ports are loose and inoperative. not sure if I can pull the main board and re-solder them. TV is in use and wall mounted.. this TV has Version SQ01 on the sticker on the back along with the model and serial number.
    when looking at used Main boards on Ebay, I see some listed under the Samsung Model number and version SQ02 for sale, but none for version SQ01, I am not sure if they interchange and don't really want to disassemble the tv to look at the Main board part # sticker on the board itself...I think my neighbor wants to order a replacement main board so I can swap it out for him and that will fix the HDMI problem. I see ShopJimmy shows 2 different boards but they say to look at the white sticker on the board for the part number. does anyone know if there's a difference between models with versions SQ01 and SQ02 ? Thanks.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Samsung LN40B500P3FXZA HDMI LOOSE, MAIN BD.QUESTION
    well, I guess you answered the question yourself. Either you solder some new hdmi ports to the old main board, or replace the main board. Yes, the version of the main board does matter, since it could be that the other version has a different panel, or something else.
    • MisterD
      • Oct 2012
      • 668
      Thanks for the reply, I Appreciate it.
        • 12332
        • U.S.
          • 12332
          • U.S.
          Thinking that both those boards on shopjimmy will work, should really match sticker numbers to be sure, one has a Y and one has a K at the end but they both work.
          • R_J
            • 9627
            They likely have different main boards to match different panels which may or may not be interchangeable, Look at the LVDS connectors and you will see they are slightly different
              • 12332
              • U.S.
              https://www.shopjimmy.com/catalogsea...LN40B500P3FXZA
              • MisterD
                • Oct 2012
                • 668
                Okay, we will remove the back to access the board and get the actual part number off the Sticker to be safe. Thanks.
                  09-07-2024, 05:50 AM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
                • mrautom8
                  Samsung TV UN75H6350AFXZC main board schematics?
                  by mrautom8
                  Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                  Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                  While relay is on, all voltage rails are present and steady (scoped) on main board.
                  I love a good logic puzzle but getting lost without any schematics.
                  No shorts on ANY capacitor main board.
                  Thermal camera shows 3.3V inductor getting warm instantly but...
                  10-19-2025, 06:32 PM
                • Yanleb
                  Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                  by Yanleb
                  Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                  If they are not compatible why did Samsung give them the same part number to begin with?
                  08-04-2025, 11:35 PM
