Is this PSB still work saving???
  • tvprobs
    • Aug 2018
    • 27
    This power supply had a resistor burn up in it. I'm curious if it's worth trying to save as there is a hole in it. Still seems pretty usable, but i've never had one this bad. Fuse did not blow, and other parts around it seem to be in working order as well. Cleanup on this has been minimal so far as i just wanted to be able to post pictures first. Also, if this is worth saving could someone help me identify the resistor needed to throw in there. Board is and LG 2300KEG031A.
    thank you
    Re: Is this PSB still work saving???
    You need to remove the carbonized section.
    I would also check the components on the output side of the resistor to see if anything is shorted out, it can also be due to cold solder joints on the resistor leg.
    Can we see the pictures of the resistor?
    Schematic:
    • SLK001
      • May 2014
      • 264
      If it's your board, I would try to save it. If it is a paying customer, I would get a new board.
      Any insight on what cause the resistor to blow? It takes a lot of current to turn a resistor into a plasma jet that burns everything in its path.
      • tvprobs
        • Aug 2018
        • 27
        Schematic:
        Here's a picture of the resistor and the fuse. Somehow the fuse is still good, just got so hot that it "fused"(no pun intended) to the clip that was holding it on one side. I've checked other components in the circuit path and we seem to be ok. particularly the diodes (there are 3) immediately after the resistor before leading to other parts and they check out.
        FYI. I'll likely keep this TV for now and replace the board altogether if i give it to someone i don't know. But if it's worth salvaging i would like to try to get it up and running.
          Did you try measuring the resistance of that resistor? I think the problem was bad solder joints on the resistor legs.
          • tvprobs
            • Aug 2018
            • 27
            I measured and got 4.3K Ohm. Would that be pretty accurate even when it's burned up like that? Also, when replacing it should i use a different type of resistor. Looks like it should be a carbon film. Would there be benefit to changing to a different type or just get the same kind?
            Thanks for your input by the way. It's extremely appreciated
              Did you look at the schematics/ I gave you the link to download.
              • R_J
                • 9624
                I don't think the resistor is on the schematic, The shopjimmy picture seems to show a 1.21MΩ 5% But that does'nt seem correct? I believe it is a a 120Ω, You shuld also check D130,D131,D101,D101a,D101b
                • tvprobs
                  • Aug 2018
                  • 27
                  FYI: Using the Shop Jimmy PHOTO!!!!
                  All diodes you listed seem to check out.
                  I tested the resistors R2 and R3 as they seem to match the resistor in the photo. They measured at 120 Ohm.
                  Also, I found U101 had a pin that was burned up. Following the trace of the burned pin, i found D106A appears to be bad and possibly the resistor at R101 is only giving a reading of 1.6 Ohms. I'll pull them out of circuit when i get time. However, I think this board has promise to be resurrected and it may just be swapping some components and re-soldering some joints throughout the board.
                  • Diah
                    • Feb 2013
                    • 6583
                    this is remind me on CRT TVs before we face the hot area on PWB section catch fire. we used to replace and re connect any hole on boards and they worked. but this an important to replace most ceramic cap on the area.
                    • tvprobs
                      • Aug 2018
                      • 27
                      So i pulled a few components that i suspected bad from the blown resistor all the way up to the IC labeled U101. Judging from the schematic R101 tests well at 4.7K Ohm. However, the diode D106A shows open either way i test it. It seems to have failed causing the burn up of the IC on the pin 7 Drain. I'm looking to replace this diode but can't seem to find anything online when i look up T2D89. Not sure what i should sub in for it. Any help there would be awesome. Once the IC, Diode, and Resistor are in place i think i can at least try to plug in the board.
                      • R_J
                        • 9624
                        The diode is likely good, it would be a tvs/zener diode and will check open, similar to the P6KE series
                        • tvprobs
                          • Aug 2018
                          • 27
                          Ok, i'll have to do some research on TVS diodes. That one stumped me. Any idea what may have caused that drain pin to burn up? When i pulled the IC out the pin just came right off. Or should i look to just get power up and going on the board and see what happens? I uploaded the schematic that Bud found.
                            can we see the U101 that has the pin burn up and good clear picture of that section?
                            And good clear straight shot of the whole top and bottom side of the board?
                            • tvprobs
                              • Aug 2018
                              • 27
                              Here are the pictures. I uploaded 2 from shop jimmy as it is the same board and shows all components in place.
                              I also have the IC FSQ510 showing the pin missing where it burnt up. There are also pictures of my board front and back. Not was well lit, but i can get better lit ones if needed.
                              • R_J
                                • 9624
                                It's likely the ic just shorted (power spike maybe) and burnt, the only other protection was the R101A resistor which also burnt. I would also change C104 as that standby circuit runs all the time.
                                • tvprobs
                                  • Aug 2018
                                  • 27
                                  Thank you. just one last question. What's the best type of resistor for that R101A spot for longevity? Obviously there's a lot of voltage running through there and i want to be sure it's going to hold up. Is there benefit to a metal film vs. a carbon film?
                                  • R_J
                                    • 9624
                                    Remember it is acting like a fuse so you want it to open when required, either should be ok, metal film flame proof would work ok
                                    • tvtimmy
                                      • Mar 2015
                                      • 1160
                                      • usa
                                      When the fsq510 goes bad it will smoke the resistor everytime, especially when a bigger fuse is inserted. Replace the FSQ510, the resistor(I use 1 watt), the fuse with the holder resoldered in, and touch up all the transformer mounting pins and all things screwed to heatsinks, and it should be fixed.
                                      • tvprobs
                                        • Aug 2018
                                        • 27
                                        This is why i love this site. The details bring it all together for people like me trying to learn beyond the big picture of it. I've got the parts ordered and should have them early next week. Slowly stocking extras as i go for future use. I'll check back regularly in case there's any additional input or concerns that we haven't discussed.
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • ohren
                                          What problems could this blown cap cause in a Marantz SR5400?
                                          by ohren
                                          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
                                          R533 right below it in the photo is charred, but measures the correct value.
                                          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
                                          10-21-2025, 09:02 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
