Is this PSB still work saving???
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Is this PSB still work saving???
    Let us know the outcome .
    • tvprobs
      • Aug 2018
      • 27
      UPDATE!!! Power supply is working.... TV is powered on. Sorry i wasn't able to post sooner, but it's been a couple days and we're still up and running. Thank you all for the input. Definitely stepped up my understanding a little bit.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Good job!
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
        • ohren
          What problems could this blown cap cause in a Marantz SR5400?
          by ohren
          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
          R533 right below it in the photo is charred, but measures the correct value.
          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
          10-21-2025, 09:02 AM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
