Lg 55le5400-uc 'no audio' ?
  • Audioplus
    • Feb 2012
    • 157
    Audio quit on this LG LCD Hybrid, manufactured in 2010. Has picture but audio quit. Can someone tell me if audio is supported via Main Board or LED Driver Board? LED Master or LED Save? My gut feeling it's the Main board and an Eprom Issue
    Thanks a Bunch!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Lg 55le5400-uc 'no audio' ?
    It's mainboard, have you tried headphones ? Doubtful it's eeprom, check the audio IC circuity and amp section, I've also fixed no audio on an LG with a reflow of the BGA on the main IC.
    • Audioplus
      • Feb 2012
      • 157
      I picked a board up EAX61532702(0) TV sight unseen from a supplier, but it has a EAX61532705(0). Another lesson to check parts out first! Must not be compatible with the digital board. I'll check into that reflow.
      Thank you!
      • R_J
        • Jun 2012
        • 9625
        This board uses a seperate ic for speaker out and headphone out, so like diff said, check the headphone output
        The speaker output ic is suppled by the +24 volts from the power supply
        • Audioplus
          • Feb 2012
          • 157
          I suspected a power supply issue as a potential culprit as well, these 10 year old hybrid designs seem like there are many variables? I may be inheriting this set from a client that is probably upgrading to a larger 4K set. I'll report further success story if anyone wants to hear it?
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
