samsung ue55ju6800 problem with brightness
  • george_gpu
    • Dec 2015
    • 77
    • greece
    good day
    It has difference upper , rearmost has 1/4 of the normal brightness
    first photo is with problem ,second is after reflow tcon but last for 5 days only
    https://we.tl/t-iXPSvuEpQP
    It is tcon or panel fault (cof bad ) ?
    • 12322
    • U.S.
    Re: samsung ue55ju6800 problem with brightness
    Try uploading pictures here, not dealing with unfamiliar sites.
    • george_gpu
      • Dec 2015
      • 77
      • greece
      Goodmorning i attach photo
      • budwich
        • Jul 2015
        • 3097
        gamma chip problem... maybe.
        • george_gpu
          • Dec 2015
          • 77
          • greece
          AS15 F ?
          but only make problem in up area of panel ?
          • budwich
            • Jul 2015
            • 3097
            input a test screen for gamma and you will see what the result is.
            • george_gpu
              • Dec 2015
              • 77
              • greece
              you mean menu\support\selfdiagnosis\picture test ?
              panel is:55B6AU0TJ
              • george_gpu
                • Dec 2015
                • 77
                • greece
                Good day check after the test
                  • 12322
                  • U.S.
                  Are you using hdmi? can try different hdmi cable or other source like dvd player or just over the air antenna, sometimes a cable box reboot helps, could also be bad leds, make sure you have a good connection of lvds cable from tcon to mainboard.
                  • george_gpu
                    • Dec 2015
                    • 77
                    • greece
                    This is with tv antenna ,lvds i ckeck it ok.
                    You think it has low bright from up led bar ,i have to take off panel for tets it?
                      • 12322
                      • U.S.
                      That would be my guess, could try testing the backlights before you take it apart, have to be VERY careful with the panel, they are flimsy and very easy to break.
                        • 12322
                        • U.S.
                        Here's some basic testing on a samsung un32, not your exact model but it gives you the info on how to test. https://www.youtube.com/watch?v=EgRKJAqYqeo
                          Can we at least see the pictures of the whole backside of the TV showing all the boards?
                          What is the power supply board P/N? BN44-??????
                          You need to do basic Voltage checking first.
                          • jjanssen7
                            • Nov 2012
                            • 252
                            FYI- In my experience this model has a problem with backlights that when one of the leds fail it can have a display like that.
                            • budwich
                              • Jul 2015
                              • 3097
                              so "reflowing the tcon" somehow causes the backlights to work ok... :-) not sure how that happens.
                                • 12322
                                • U.S.
                                That is a MAJOR heas scratcher
                                  https://www.shopjimmy.com/samsung-bn...-con-board.htm
                                  More likely that the T-CON controls the backlights level for the two LED strings for the Dynamic contrast function via connector CN500.
                                  That is why it is important for OP to provide the pictures of what we are dealing with.
                                  • jjanssen7
                                    • Nov 2012
                                    • 252
                                    It is a curious problem with these models, I've never had one that the tcon fixed the brightness problem but I never really tried too hard. I have new tv's with cracked screens and swapping the panel always does the trick. When I do that, I pull apart the original TV and most often find a burnt LED.
                                    I'm curious about the reflow tcon though because I've had one or two that worked sometimes then not other times. I assumed that it was because one of the LEDS was on the way way out (they were always high hour TV's), but I suppose a failing tcon could cause the same end result. I'll be following this thread with interest.
                                      Hopefully the OP will come back and show us some pictures and some Voltage testing.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        I am still curious also though. If it was a string issue, then supposedly this set is edge lit then how does the test pattern with the gradients light somewhat in the borders at the top but have such a nice "boundary" of "lost brightness " in his first display.... doesn't seem right for a led display issue versus a problem elsewhere.
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
