Samsung UN55KS8000fxza turns on then off repeatedly
  • nwelec
    • 61
    • usa
    TV turns on then almost immediately shuts off and does this for as long as it is plugged in. I did remove power to the main board and the tv stays on. I put what I thought was a good replacement main board in and the same problem. I am now wondering if I am dealing with a bad panel.
  • nwelec
    • 61
    • usa
    Re: Samsung UN55KS8000fxza turns on then off repeatedly
    thought I would add the voltages I get when the panel lights up at CNL801
    1 thru 4, 18 thru 20 and 27 are gnd
    7, 9 and 11 vamp 13v
    13, 15, & 17 13v reads 13v
    21, 23, 25 & 29 pwm 1.3v
    8 od_LEV 3.34v
    10 Fail_ct 3.34
    12 OD_o/f 3.3v
    14 blu_o/f 4.1v
    16 Power_o/f 3.34v
    22, 24, 26 & 28 PWM 2.25
    30. ana_dim 2.5v
    I hope this helps some. The voltages do drop to 0 or almost 0 when the tv restarts.
    • nwelec
      • 61
      • usa
      Finally figured out it is a bad panel. I got one in with a cracked panel and it does the same thing. Hope this helps someone out there.
        • 12331
        • U.S.
        Check the components on your driver board, might get lucky.
        • nwelec
          • 61
          • usa
          OK, Thanks.
            • 12331
            • U.S.
            To clarify, the driver board is the board attached to the screen, some call it tab bond board it usually is not easy to get at without a little disassembly.
            • nwelec
              • 61
              • usa
              Thanks and yes I knew that.
              • nwelec
                • 61
                • usa
                Think I finally found the problem. I took nomoresonys advice and checked the driver board and found one of the flat ribbon cables that is between the right side driver boards was crimped. If I remove it the picture no longer flashes and if I put it back but not quite in straight I get a scrambled picture. Now I just need to find a undamaged flat ribbon cable to test my theory
                • nwelec
                  • 61
                  • usa
                  Spoke too soon. I found what looks like two burnt resistors on the far right board. Any know how I can find replacements?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Check the far left board as they are usually symmetrical. The values are written on them.
                    • nwelec
                      • 61
                      • usa
                      I did and it is not configured the exact same way so I found 4 resistors on it but different values.
                      • nwelec
                        • 61
                        • usa
                        Update to this problem in hopes it will help someone else. Removed the two bad resistors on the far right (looking at the back) driver board (again thanks to nomoresonys) and now the tv works fine.
                        • morinb
                          • Jul 2020
                          • 4
                          Thanks so much for posting this. I have a UN55KS8500FXZA that's having the same problem you had. I replaced the mainboard and the power board with no luck. After reading your post, I looked at the boards that run along the bottom of the screen (driver boards?) and I found burnt resistors on the far-right board and on the far-left board (link to pictures).
                          As someone who's only ever done a minimal amount of soldering/desoldering (and even that was well over a decade ago), I was hoping somebody here might have some tips or tool recommendations for removing these resistors. Any help would be appreciated!
                          And thank you again!
                            • 12331
                            • U.S.
                            A little demo there, there's a ton more if needed: https://www.youtube.com/watch?v=8JM4oCpWnjU
                            • morinb
                              • Jul 2020
                              • 4
                              Awesome, thank you, wish me luck
                                • 12331
                                • U.S.
                                For sure, let us know how you get on.
                                  09-07-2024, 05:50 AM
                                • Egidio85
                                  Samsung UE55F8000SZ Turns on and off immediately
                                  by Egidio85
                                  good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                  This defect happens continuously, hearing the classic click of the relay every time.
                                  Power supply board BN44-00636B
                                  disconnecting the mains and lamps from the power board always causes the same problem.
                                  Is it normal that without anything connected this power supply turns on and off cyclically?
                                  any suggestions on what to check?
                                  thanks in advance
                                  03-11-2025, 12:45 PM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
