Samsung UN55KS8000fxza turns on then off repeatedly
  • nwelec
    • 61
    • usa
    TV turns on then almost immediately shuts off and does this for as long as it is plugged in. I did remove power to the main board and the tv stays on. I put what I thought was a good replacement main board in and the same problem. I am now wondering if I am dealing with a bad panel.
  • nwelec
    • 61
    • usa
    Re: Samsung UN55KS8000fxza turns on then off repeatedly
    thought I would add the voltages I get when the panel lights up at CNL801
    1 thru 4, 18 thru 20 and 27 are gnd
    7, 9 and 11 vamp 13v
    13, 15, & 17 13v reads 13v
    21, 23, 25 & 29 pwm 1.3v
    8 od_LEV 3.34v
    10 Fail_ct 3.34
    12 OD_o/f 3.3v
    14 blu_o/f 4.1v
    16 Power_o/f 3.34v
    22, 24, 26 & 28 PWM 2.25
    30. ana_dim 2.5v
    I hope this helps some. The voltages do drop to 0 or almost 0 when the tv restarts.
    • nwelec
      • 61
      • usa
      Finally figured out it is a bad panel. I got one in with a cracked panel and it does the same thing. Hope this helps someone out there.
        • 12210
        • U.S.
        Check the components on your driver board, might get lucky.
        • nwelec
          • 61
          • usa
          OK, Thanks.
            • 12210
            • U.S.
            To clarify, the driver board is the board attached to the screen, some call it tab bond board it usually is not easy to get at without a little disassembly.
            • nwelec
              • 61
              • usa
              Thanks and yes I knew that.
              • nwelec
                • 61
                • usa
                Think I finally found the problem. I took nomoresonys advice and checked the driver board and found one of the flat ribbon cables that is between the right side driver boards was crimped. If I remove it the picture no longer flashes and if I put it back but not quite in straight I get a scrambled picture. Now I just need to find a undamaged flat ribbon cable to test my theory
                • nwelec
                  • 61
                  • usa
                  Spoke too soon. I found what looks like two burnt resistors on the far right board. Any know how I can find replacements?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Check the far left board as they are usually symmetrical. The values are written on them.
                    • nwelec
                      • 61
                      • usa
                      I did and it is not configured the exact same way so I found 4 resistors on it but different values.
                      • nwelec
                        • 61
                        • usa
                        Update to this problem in hopes it will help someone else. Removed the two bad resistors on the far right (looking at the back) driver board (again thanks to nomoresonys) and now the tv works fine.
                        • morinb
                          • Jul 2020
                          • 4
                          Thanks so much for posting this. I have a UN55KS8500FXZA that's having the same problem you had. I replaced the mainboard and the power board with no luck. After reading your post, I looked at the boards that run along the bottom of the screen (driver boards?) and I found burnt resistors on the far-right board and on the far-left board (link to pictures).
                          As someone who's only ever done a minimal amount of soldering/desoldering (and even that was well over a decade ago), I was hoping somebody here might have some tips or tool recommendations for removing these resistors. Any help would be appreciated!
                          And thank you again!
                            • 12210
                            • U.S.
                            A little demo there, there's a ton more if needed: https://www.youtube.com/watch?v=8JM4oCpWnjU
                            • morinb
                              • Jul 2020
                              • 4
                              Awesome, thank you, wish me luck
                                • 12210
                                • U.S.
                                For sure, let us know how you get on.
                                • paul85
                                  Samsung un40h5003 turns on when plugging it in
                                  by paul85
                                  I have a weird one. My in laws gave me a un40h5003 Samsung LCD TV that turns itself on when you plug it in and neither the power button on the TV nor the remote do anything, but other buttons do.
                                  Simple issue I figured, so I opened up the back, and unplugged the power button on the TV from the cable. Retested and it still turns itself on automatically. I pulled the batteries out of the remote and even had the remote in another room and same thing.
                                  Any ideas why this would be happening? No obvious capacitor issues, no bulging, no issues on either power or main board...
                                  12-04-2022, 04:58 PM
                                  Samsung RV 15 Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung RV 15 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 boardview and 15 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung RV 15 Notebook is...
                                  09-06-2024, 05:27 AM
                                  Samsung ATIV NP915S3G Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung ATIV NP915S3G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP915S3G boardview and NP915S3G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung...
                                  Samsung P-R60FE0B Specification for Upgrade or Repair
                                  This specification for the Samsung P-R60FE0B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P-R60FE0B boardview and P-R60FE0B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung P-R60FE0B...
                                • EvansEssence
                                  Samsung UN55D6003SFXZA TV turns off after 20-30 seconds
                                  by EvansEssence
                                  Hey guys! I saved an older Samsung tv from the recycle bin to tinker with as a hobby. Looking for some help as to what else to check/replace.
                                  The issues it had at first was it would randomly reset its picture settings, this slowly devolved into it rebooting itself and the control board becoming unresponsive. Now it has finally gotten to the point where it no longer turns itself on when plugged in, but when I turn it on with the remote or power button it will boot to a blank input work for 15-20 seconds then turn itself off. I found if I pull up the menu it will actually freeze my...
                                  02-04-2023, 08:49 AM
