Bush 50/211f slow turning on
    I have picked up a Bush TV model 50/211f, turns on ok sometimes, other times it takes a while. I've had the power board out but all of the caps look ok. Caps are 'Chang' - a brand I've never heard of. The board is from 2011 so lasted over 8 years. Shall I grab a new board for £20/£25 off ebay, or can you see any bulging in these? Or, do you have any methods I could try to reveal the bad cap....
    I don't have a capacitance meter but do have a few different testers around, so if worst comes to worst i can take them out of circuit tomorrow and test that way?
    Thanks in advance for any advice here.
    https://ibb.co/F8LhDcF
    https://ibb.co/nPdjvr1
    https://ibb.co/q0bmh1b
    https://ibb.co/JqTy6RB
    https://ibb.co/X7vVcfh
    https://ibb.co/L5qXmRY
    https://ibb.co/VmryMZ2
    https://ibb.co/Cm6HXKp
    https://ibb.co/Kjcb51z
    https://ibb.co/J5pt97d
    https://ibb.co/80TKr5t
    Re: Bush 50/211f slow turning on
    Heat from a hairdryer is sometimes a cheap way of testing your faulty cap theory. Warm areas up and see if it helps the turning on.
    A cheap component tester is less than £10 and that will definitely identify your faulty caps out of circuit.
    You can post your photos on this site using the advanced tab, so those security minded can see them.
