Sony XBR-65X900C Sporadic Issues
    replied
    Re: Sony XBR-65X900C Sporadic Issues
    Looks like they want about 200+ bucks for the mb, wonder if a repair service might be more economical.
  • diif
    replied
    I thought this approach was pretty clever: https://www.youtube.com/watch?v=ZDQNOU2w_ek
    Yes, a novel idea but a DDR3 chip is smaller and thinner than a processor on a TV.
    Heating a small part of the board to 220c leaving the rest cold isn't a very good idea for thermal shock reasons. It's the reason rework machines have a bottom heater.
    replied
    replied
    A reflow shouldn't hurt IF you monitor your temps closely.
  • Michale32086
    replied
    Originally posted by budwich
    I recently have an xbox original (2003) that would boot up some times and others not so. Moved it from one area to another (obvious different plugs), it would boot up fine. Moved it to another area where there is an xbox that works fine... same cabling used on the "bad one" would not boot. I took the housing off to look inside while booting.... then I saw the fan having a hard time to start... it would go a bit and then stop. The fan gets its power from the main board.... I looked around and see that 3 of the 3300uf 6.3 v caps (hint... likely in the 5v circuit) in the main board area appear to have slight budge and measure out at 10kuf ... :-(
    I haven't replaced them yet as local parts don't carry low voltage ones.
    Anyway, your problem seems to point to issues with the 5v supply / generation.... hence my suggestion.... I would take a closer look at any place that needs or appears to need 5v plus juice... meaning the voltage might be OK but not enough current.
    If I can't do a successful reset today maybe you can run thru some voltages with me on Tuesday???
    Here are the pics for the 2 power boards...
    If the voltages check out, I think I am just going to break down and buy the Main Board..
    Kick myself to think that the LAN issue COULD have fixed the original problem had I not gone crazy with the reflow equipment..
  • Michale32086
    replied
    Originally posted by Diah
    your TV issue are communication between ram and main processor i think.. as you plug it with LAN all recommend apps and smart apps loading and they occupied the ram so there are no more space to let the firmware run. CPU are responsible to clear the ram and load other script. you can repeat this methode how much you can till clear it.. this will never harm the set at all. other wise you need to reflow the cpu or ram.
    Yea, I think a reflow is what got me into this mess.. I might have fried something...
    I'll play with resetting it more today... Maybe something will 'pop'...
  • budwich
    replied
    Originally posted by Michale32086
    Yea, I have moved it back and forth from the display area to the work bench... I am always petrified every time I do it, but I am becoming more comfortable with moving it back and forth...
    I have the back off and there doesn't appear to be any bad caps or burn marks..
    One of my first thoughts was the symptoms are like the Samsungs when they have a couple charred connections off the Power PCB.. But no such luck with this one..
    Funny you should mention this..
    I seem to have a different problem now.. I see a different boot up process when the ANDROID animation is quicker and then I see a ANDROID IS STARTING.... loading apps message and then the TV shuts off...
    NOW the biggest problem seems to be that the TV tries to boot up, but shuts off at various stages of the boot process..
    And I still can't get a valid Factory Reset...
    Next time I move the TV to the workbench, I'll get some shots of the power boards...
    Thanx for the reply.. Much appreciated..
  • Diah
    replied
  • Diah
    replied
    you dont need to keep hold them pressed
    from the point you plug it back to wall socket count from 1 to 10 then release and never touch it any more
  • Michale32086
    replied
    OK, did that...
    At the point to where i was holding the PWR and VOL - buttons, the green LED came on... I continued to hold the buttons.. after a few secs, the green LED went off.. I continued to hold the buttons, after about 20-30 secs the green LED came back on.. Continued to hold the buttons, then the green LED went out.. This repeated for about 4 or 5 times.. I continued to hold the buttons... Then the green LED went out and never came back on..
    I never saw anything on the screen...
  • Diah
    replied
    do exact the following.
    disconnect the LAN and move any USB or other stuff conected to the TV SET. so the TV stay solo
    while its at start and before it goes off plug it out from wall socket.
    keep it plugged out about at least 5 minute or more.
    press now first the power on the TV set .. keep it pressed and then press Volume -
    keep both pressed and plug it at wall socket
    keep them pressed even the LED change to Green. so round 10 second. and leave it let it do what it will. if you saw white with round red blue circle mean it reset all hard ware driver.. then it will show welcome screen... dont touch it. it will from alone restart and the circle will show again.. leave it till it show you the welcome screen with start music. gross finger
  • Michale32086
    replied
    Yea, it's shutting down before I can get into it to do anything.. I think all my efforts prior to the LAN solution might have frak'ed things up beyond belief..
    So frustrating..
  • Diah
    replied
    if there are no air mouse under your hand.. you still can use any other PS2 USB wire mouse, it will do same job
  • Diah
    replied
    ANDROID IS STARTING.... loading apps ..... mean this is effect of the way you tried before of hardware reset via volume- power.. as its didn't finish it as it should.
    i dont think there are any issue with power.. you are now at level of firmware nand level issue . this you can try to trik the nand by freezing or warming up. either the sony from my experiences suffer from bad HDMI / USB Input sockets.. any one of them if Brocken or shorted will get what you have before switching to HDMI 1 alone. so inspect them
  • Michale32086
    replied
    did you used the sony apk from the market? i wrote to you before you can use air mouse to navigate too
    Yea, I don't have an air mouse for it..
    Thanx for the help.. I never thought I would get this far!!
    I am thinking now that it might be power related since it now shuts off even before it gets to the display...
  • Michale32086
    replied
    looks like you are almost there. I am wondering if perhaps you have a powering issue (power board). Have you taken the back off to look at the boards yet (I know it might be a gamble with such a thin set).
    Anyway, I am thinking that the 5v supply (if that voltage is used) might have a marginal cap in the circuit somewhere such that it isn't quite providing enough "juice" when things are trying to get running. You could perhaps verify the stuff associated with the key pad inputs to see if they are associated with anything 5v also. Get the feeling with the USB stuff that you have gone thru which might be drawing / running on a marginal 5v also.
  • Diah
    replied
  • budwich
    replied
    looks like you are almost there. I am wondering if perhaps you have a powering issue (power board). Have you taken the back off to look at the boards yet (I know it might be a gamble with such a thin set). Anyway, I am thinking that the 5v supply (if that voltage is used) might have a marginal cap in the circuit somewhere such that it isn't quite providing enough "juice" when things are trying to get running. You could perhaps verify the stuff associated with the key pad inputs to see if they are associated with anything 5v also. Get the feeling with the USB stuff that you have gone thru which might be drawing / running on a marginal 5v also.
  • Michale32086
    replied
    OK, something is DEFINITELY happening..
    With the LAN plugged in, I don't get that funky black/white menu at the top..
    It does to the APP screen and actually shows the correct time..
    So, one hurdle overcome..
    But the remote and the buttons on the TV still don't work.. I can't do a factory reset. Same symptoms.. Green LED comes on then shuts off and the TV stays off...
    The TV also shuts down, but sometimes it LOOKS like it shuts down (black screen) but the power LED is still white...
    So, definitely progress!
  • Diah
    replied
    actuality even if you are at limited access profile the RC should work. i think your RC had issue too. reset it (( take the batteries out and press Power for at least 10 second the script on the RC chip will be reset and it should work.))
  • HarryZ
    Sony XBR-49X800G networking issues
    by HarryZ
    Aloha. First post here, hope I can find someone to assist me.
    I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
    My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
    01-26-2024, 04:49 PM
  • cheeky2
    Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
    by cheeky2
    I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
    Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
    The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
    Details:...
    08-17-2023, 04:34 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • PontyPCs
    Sony Android TVs eMMC Issues
    by PontyPCs
    Hi people.
    I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
    12-10-2023, 10:43 AM
  • ptcriserx3
    Sony trinitron crt bowed and side color issues
    by ptcriserx3
    Hi
    Ive got a vintage 2001 sony trinitron flat tube tv
    The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
    See many images attached...
    Just windering if this is not fixable or something i can correct without getting too invloved
    Im trying to sell the tv
    06-17-2023, 07:27 PM
