XBR65HX950 no video after 1 min
  • anthonystv
    • Jun 2014
    • 73
    Tv loses video backlight stays on replaced TCon same thing Rd in board drops. 8.8v and the video along with it. Anybody seen this ?
    Re: XBR65HX950 no video after 1 min
    What happen to the Voltages on various test points on the T-CON if no ribbon cable between the T-con and the LCD panel connected?
    • anthonystv
      • Jun 2014
      • 73
      I have narrowed this down to something on the panal even though the picture is perfect Ill update you when I get a chance going on the road now
        It can be as simple as shorted/leaky caps on the tab bonding board, worst case will be bad COF.
        • anthonystv
          • Jun 2014
          • 73
          Ok so here is the update. I Found a 12 v source on the tcon that apears to feed the pwm for the 17v source and the 8.8 v source. This is the source that was dropping I fed an external 12v to it and the picture popped back on but I slowly watched the current rise from. 1/2 amp to 1 amp then the tv shut down and rebooted .. So I thought about what you said and I narrowed it down it is the panel or more likely some cap on panel board. I'll be taking that apart next. .. but I determined that one ribbon of the 4 would cause the shutdown. Disconnecting. It the tv would stay on
          • anthonystv
            • Jun 2014
            • 73
            I don't think it's a COF I have a perfect picture!
              But it works for a while then picture goes away, correct, so when COF heats up the problem then occurs, so that is still possibility, they do run hot. The best hope will be just bad MLCC.
              • budwich
                • Jul 2015
                • 3097
                which one of the 4 tcon to panel cables are you "successful" with in getting the "non-shut down".
                Further, if this set has tabs and edge boards along the side also, you can further isolate your problem by disconnecting the small corner cables that interconnect the bottom edge board to the side edge board. IF not, you can also try isolating by disconnecting the "U" ribbon cable that sometimes exists on "very long" bottom edge boards to interconnect those. These actions might help you isolate where / which area you need to focus your checks.
                • anthonystv
                  • Jun 2014
                  • 73
                  It's the large on the picture on the right or the third one if you count left to right
                  • budwich
                    • Jul 2015
                    • 3097
                    OK... I think that points to a problem in the bottom edge board... possible a smd capacitor or resistor.
                    • Hakuu
                      by Hakuu
                      Hi There,
                      More Details
                      TV Model - LG OLED77G1PUA
                      07-12-2023, 02:37 PM
                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                      09-12-2024, 02:00 PM
                    • x_orange90_x
                      TCL 50S535 bad tcon or panel issue?
                      by x_orange90_x
                      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                      03-29-2025, 11:02 PM
                      GeForce RTX2080 Super Aero video gaming card issues help need
                      by sam_sam_sam
                      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                      05-07-2023, 08:12 AM
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
