Insignia LCD TV NS-39L240A13 backlight comes on then off
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    hi
    tv turns on and backlight comes on and shows please wait graphic then after 2 seconds backlight turns off and image and sound still ok
    this is a ccfl style bacjklight
    no sepearate inverter board....all part of ps..i replaced ps since they are cheap and same issue...any ideas? bad ccfl tubes?
  • shelby5041
    • Feb 2009
    • 1505
    Re: Insignia LCD TV NS-39L240A13 backlight comes on then off
    from l;ooking at a similar model 50 inch on here it seems the inverter board could be part of the ccfl assembly insdie the tv screen area ... not visable and maybe not repalceable...very odd tv...will have to take apar5t firther..its definitely not a ps issue
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Can you identify the P-DIM, BL-ON/OFF, 24V and GND wires on the PSU connector? If you can identify these wires, I could help you convert this to a LED Backlight TV.
      • Unspun01
        • Jun 2011
        • 349
        I've seen this similar design on a 50" Sanyo TV with inverter board located inside the panel.
        The thin narrow board and all transformers on the board were ok, and it was in fact a failed ccfl lamp in my TV.
        You may have luck replacing the ccfl from another TV with same diameter of bulb and end-to-end length of ccfl electrical contact pins.
        Be careful removing the ccfl lamp from the delicate plastic retainer clips because they are easy to snap. In my case, I withdrew the ccfl lamp by pulling it to the left or to the right from each support and feeding the new lamp back in the same way (instead of springing the clips apart)
        • shelby5041
          • Feb 2009
          • 1505
          good news very very bad news...it was 2 bad ccfl tubes so i just used a wire to jumper it out and then backlights worked..but i broke lcd panel when i reassembled....initially i reassembled and was ok but i could see the lcd panel was not aligned properly so i reluctantly decided to take apart again to realign and yes i cracked the screen when i tiightened the screws and something wasnt lined up properly and screen cracked....i hate dealing with lcd panels..i have done this about 4 times..fixing tv then breaking lcd panel whne putting back together
          i threw tv in trash....i was very upset i spent about 3 hrs messing with this tv modifying it and being successful only to fail at the end during reassembly of tv.....not happy at all
          • shelby5041
            • Feb 2009
            • 1505
            man i am so upset right now
            • shelby5041
              • Feb 2009
              • 1505
              so if anyone has same issue i had with insignia ccfl tv please check the ccfl tubes as it seems its a common issue on this brand or model tv.. and dont screw up like i did when handling the lcd panel
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
                Design of CCFL Backlight Inverters with Frame & Bar Cores
                Summary
                Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
                The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
                The frame and bar ferrite cores, described in this brochure, are especially designed...
                10-07-2024, 04:26 AM
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • howardc64
                Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                by howardc64
                Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                • Backlight on, no image
                • Disconnect right buffer board (view from front), left side display comes on
                • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                • Buffer board is pretty simple
                Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                07-11-2025, 04:04 PM
              • arnard
                Insignia NS-32L430A11 backlight issue
                by arnard
                I have a weird backlight issue on the above Insignia Plasma that I am coming up empty on researching.
                The display is darker on the left than on the right side of the screen. It uses 4 U shaped plasma tubes. I have had it apart deep enough to tell you that the tubes are bright as they should be at the electrode ends but dim as they get to and go around the bend.
                Since it is all 4 tubes it seems like it would be an inverter/backlight board but obviously can't be a blown up component as it does still somewhat work. I'm thinking low voltage but no idea where to go beyond...
                06-10-2023, 01:36 AM
