TCL LE48FHDF3300Z - No Picture
  • nomoresonys
    • 12276
    • U.S.
    Re: TCL LE48FHDF3300Z - No Picture
    A replacement eeprom might be worth a shot, if one is available.
    • nomoresonys
      • 12276
      • U.S.
      I see an eeprom here from shopjimmy, not sure if it's a match for your tv, I would call or email them with your board numbers and sticker number and see if they have one. https://www.ebay.com/itm/Tcl-LE48FHD...wAAOSwYGFUuBEc
      • AtomicPunk
        • Oct 2018
        • 26
        • US
        I did send them an e-mail. Does the EEPROM have to be programmed? Or is this just NVM and I just need to replace existing chip with a new one?
        Unfortunately I can't make out anything legible on the existing chip.
        • nomoresonys
          • 12276
          • U.S.
          From what I read, I believe if it uses eeprom tech. it needs programmed.
          • diif
            • Feb 2014
            • 6978
            • England
            EEPROMs are a type of NVM and need programming. Shopjimmy however sells EEPROMS already programmed that can just be soldered on.
            • AtomicPunk
              • Oct 2018
              • 26
              • US
              #26
              I contacted shopjimmy via e-mail - a little surprised by the response:
              "Sorry no we do not sell the EEPROM's. You can try PTS Electronics 812-676-1200."
              • nomoresonys
                • 12276
                • U.S.
                #27
                That IS strange, I would have had to ask them, then why are you selling them on ebay?
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
                • nsab6464
                  Vizio P502ui-B1E power light turns on, but no picture
                  by nsab6464
                  Hey guys,
                  I have a Vizio P502ui-B1E with no display activity at all with the power light on. It broke in a very specific way, and now exhibits strange behavior when turned on (slow response to power off command, restarts every 90 sec, more below), so I'm hoping that someone with experience working on this TV can point me in the right direction.
                  I already tried the 2 most common fixes with no luck:
                  - Replacing the T-Con board.
                  - Re-flashing the firmware on the U202 chip (from here: https://www.badcaps.net/forum/showthread.php?p=840012)
                  Here's exactly...
                  06-21-2019, 12:25 AM
                • ipatch
                  troubleshooting microsoft surface pro 4 no power no led charge light
                  by ipatch
                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                  10-05-2023, 11:59 AM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                  03-31-2024, 02:12 PM
