Can I replace a TV main board with one from a smaller screen size
  • Kairi
    • Nov 2013
    • 51
    • United Kingdom
    I have in my possession a Samsung LE47C750R2K with a faulty main board which has a part number of BN41-01423B BN94-03388E.
    It seems like this board is used in both 40 inch and 47 inch screen TVs (LE40C750R2K and LE47C750R2K). The boards are physically identical with the same part number but there's a bar code sticker on it with the TV model written on it.
    I would like to know whether it's possible to fit a main board intended for the LE40C750R2K in a LE47C750R2K. Or are there some sort of programming to make it work for a particular screen size only rendering it non-interchangeable between the different screen sizes?
  • R_J
    • 9627
    Re: Can I replace a TV main board with one from a smaller screen size
    It will likely work, give it a try. If the picture is not right go into the service menu and change the model or panel number
    • Diah
      • Feb 2013
      • 6614
      first go to Samsung website for firmware.. if you find the firmware all same size as you mentioned your type LE47C750R2K and other size then go head and need to do at SM as R_J suggest . . if there firmware as update each panel size individual then will be hard to do
      • Kairi
        • Nov 2013
        • 51
        • United Kingdom
        I went to the Samsung website but there doesn't appear to be firmware available apart from 2 upgrade files which appears to be the same
        https://www.samsung.com/uk/support/m...E40C750R2KXXU/
        https://www.samsung.com/uk/support/m...E46C750R2KXXU/
        I wan to be sure that the board intended for the 40 inch will work in the 46 inch before I commit to buy the replacement board.
        • Diah
          • Feb 2013
          • 6614
          both firmware same size. also MB can be used. only need to adjust the change at SM
          • neilc6
            • Nov 2015
            • 1550
            I have put a Samsung UN40D main board in UN46D (BN97 part number matched and shopjimmy said they were compatible) and an LG 47LN main (had lying around and purchased another time because it was cheaper) in a 42LN. TVs worked without having to make changes in the service menu.
            • Kairi
              • Nov 2013
              • 51
              • United Kingdom
              Thanks guys. I've ordered the 40 inch version.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ygorsan
                by ygorsan
                🧩 Problem Summary:
                • I
                07-28-2025, 08:34 AM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • mrautom8
                Samsung TV UN75H6350AFXZC main board schematics?
                by mrautom8
                Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                While relay is on, all voltage rails are present and steady (scoped) on main board.
                I love a good logic puzzle but getting lost without any schematics.
                No shorts on ANY capacitor main board.
                Thermal camera shows 3.3V inductor getting warm instantly but...
                10-19-2025, 06:32 PM
